BCD325P2/BCD996P2: Interested in a BCD325P2 Unit
a727469
Maine
A few things. First, do you really need a handheld? You say you have a discone and runs to an office, might be better if you got an sds200 or bcd996p2. In my opinion the displays are much easier to read and buttons easier to use etc if you do not need portability.
I owned a 325 and it was a great radio with the drawbacks stated by others. Also as stated, if you have the money get the sds100 or sds200.
I will probably be criticized for this, but an option we should be mentioning to anyone considering a new scanner are the multiple on line scanner feeds (broadcastify, openmhz, etc). for those not wanting to either spend the money or fairly large amount of time setting up today’s type of scanner especially if a feed does an adequate job for the area involved. And, as an example, if some of listening is dmr, there are reasonably price ham radio radios that do dmr and combined with feeds could provide good coverage at low price. I know this does not cover p25 etc but again just another option. Yes, I know of the drawbacks, but the feeds are less frustrating for some. I use them all the time along wth my radios.
Again, some people just want to hear the action and not devote time to radios. Some like playing with radios and many love both hearing and playing.
sfb88
Baltimore, MD
Another thing to consider about choosing the feeds is that, if you are mainly interested only in public service listening, you won't lose a large amount if your system goes encrypted in the future.
StoliRaz
£uck Encryption
If you're wondering how to set the P25 threshold, it is hidden for some strange reason. Per the Uniden manual-
P25 Threshold
This is a hidden setting accessible only by turning off the radio and pressing Hold
when you turn the scanner back on.
1.
Scroll to 'P25 Threshold' and press E/yes.
2.
Scroll to 'Auto', 'Level 5-13' and press E/yes
The "Easier to read" manual is also a good one to save-
I highly recommend downloading both and saving them.I keep a goggle folder with all my manuals. You can use a web to pdf conversion app to turn any of them into PDFs then save. Cheers
tvengr
Well Known Member
Baltimore County, MD
The P25 Threshold is not hidden in the BCD325P2. It is under Settings in the scanner menu. It was hidden the XT and earlier scanners. There were 2 settings for P25 Adjust Mode and P25 Adjust Level.
RoninJoliet
ILL
It is hidden if you don’t have the latest firmware
tvengr
Well Known Member
I don't remember the P25 Threshold setting ever being hidden in the BCD325P2 or bCD996P2. I just checked the firmware updates for both scanners. There is no mention of unhiding the P25 Threshold setting. There was a problem where the P25 Threshold setting could not be saved. That was corrected by firmware update v1.07.09.
BinaryMode
Banned
2600 dialtone blvd
The P2's withstanding (I own both), the threshold appears to be hidden in the BCD396XT. At least I don't see it in the menu, and I believe I read there is a quick key startup sequence to access it, and then I think that only works until reboot if I can remember right.
tvengr
Well Known Member
You press the HOLD button while turning on the scanner to access the hidden settings. The display will cycle through all of the background colors. Under Settings in the scanner menu, P25 Adjust Mode and P25 Adjust Level are added. That needs to be done each time the scanner is turned on.
RoninJoliet
ILL
That's what I was referring too in my post #25 , one of my 996P2 still has 1.07.09 and I have to turn it on and hold "HOLD" to access P25. Adjust Mode,...
tvengr
Well Known Member
The BCD325P2 and BCD996P2 do not have P25 Adjust Mode and P25 Adjust Level. They were only available in the T and XT models.
