Interesting problem with the APX
slobonmycob
I feel sorry for your agency if you’re the support
I have an apx that whenever it’s scanning, it switches automatically to whatever channel last transmits.
Any ideas how to fix this?
buddrousa
Look for a version TAALK BACK SCAN or it may be called something else by Motorola.
What you are saying is TALK BACK SCAN
Motorola "Scan Talkback" is a two-way radio feature allowing users to respond to an active transmission while scanning, rather than being forced to use the default transmission channel. With this enabled, pressing PTT (Push-to-Talk) during a scan allows immediate communication back to the active channel, rather than disrupting the scan. [1, 2]
Key Aspects of Scan Talkback:
  • Enabled: If PTT is pressed during a scanned call, you can immediately speak back to that group.
  • Disabled: If PTT is pressed while scanning, the scanned call is terminated, and the radio reverts to the pre-programmed Home Channel.
  • Purpose: Ensures uninterrupted, efficient communication within a programmed scan list without needing to manually switch
slobonmycob
Yes sir! Thank you 🙌
