Halfpint
Whilst out `cruising' around a few suplus sites I happened upon this antenna;
http://www.sportsmansguide.com/cb/cb.asp?a=170520
I thought that they had all disappeared some time ago and I've been kind keeping off to the side in storage the one I picked up many years ago set aside as a `just in case' antenna. By the proper assembly of the disc and cone elements you can have an antenna that is good for freqs below or above 38MHz, according to the paperwork that usually comes with them, that you can set up fairly quickly as a `temp' antenna. (Now that I've found these I've got a couple more on the way and intend to actually set up one a bit more permanent as I found that they are actually pretty good `omni ' antennas! [If my original antenna was any example you might have to do a bit of `repair' work to the very top piece where the disc and cone elements mount as that seems to sometime get a bit `dinged' in shipping. Fortunately it can be disassembled and fairly easily straightened up if you don't rush into the job.]) I did use my original one this last summer when I took a trip up to Wyoming to do a bit of `signal surveying' and between myself, SWMBO, and the two, ages 8 and 12, children it went up and down quite easily at each site we set up at. (The looks we got at one `campsite' we set up at were priceless! {VB GRIN!} However... Once the people who actually bothered to actually ask what it was heard the reception I was getting they all wanted to know where they could get one. It kinda `broke my heart' at the time to tell them that I hadn't seen anymore around and didn't know if there were any left.) A full antenna assembly comes with all the necessary mast, the disc and cone elements, guy `materials', and some fairly decent co-ax with BNC connectors on both ends and a `captive' BNC to PL259 adapter at one end. (I'd recommend that you replace the `guy wire/string' with something a bit heftier if you might think that you'll have any decent winds to deal with though I dealt with some gusts of around 35MPH with the ones my original one came with. If I put one up on a more `permanent' basis I'm going to actually probably use either wire or `parachute cord' and maybe also tie it into the side of the house with some brackets.)
