The Unication G5 pager is a dual band receiver that uses an internal VHF or UHF antenna, depending upon which version is chosen. (There are two versions, VHF/700-800MHz or UHF/700-800MHz.) the 700-800MHz antenna is a small stubby external antenna.
The pager has a hot receiver, I’ve heard it related to “commercial grade” and from what I’ve read and actually heard, it is in fact a commercial grade in quality and performance. So I finally scrapped up enough cash to get one of my own. I have the VHF/700-800MHz version. The fist thing I did once I got it programmed was to compare it to the SDS100 and a BCD325P2 on the VHF band. I was impressed with its performance. But it got me thinking about how they get an internal antenna to work as good as it does on the G5… and wonder why scanner manufacturers haven’t offered the same on their handheld units? If they did, both VHF and UHF antennas would be inboard and just the 800MHz band would have an external antenna, a lot shorter than the multi-band antennas currently used. Obviously, it’s a question of cost, but I’m guessing design also plays a large part in it. Maybe it’s just not all that practical?
My experience with handheld radio antennas are primarily related to amateur radio. And since those antennas are also used for transmitting, they need to be positioned away from the circuitry so the radiated RF doesn’t interfere or damage the radio. But scanners and pagers don’t transmit. So, why isn’t it practical to have internal antennas like the G5 has?
