"Invalid Keystore. Zeroize Needed."
2wayfreq
NM Kirk City
This comes up on the XL400 display when it starts up. Is there I have Key Names and one Keystore with the radio ID. What is missing?
rbrtklamp2
Dupage County, Illinois
Read the KIDs out of the radio is easiest way to see if you missed one. Or if you have a KFDTool thay would be the ideal tool just load your keys into that and write the whole Keyset
rjschilder
AES FTW
This also happens the first time you load a personality and you’re using OTAR/LLA. Just zeroise it from the radio or keyloader app.
rescue161
KE4FHH
Hubert, NC
This is a problem that we see on every single radio that is new. For whatever reason, OTAR profiles don't jive with L3Harris' secure settings. After the radio is programmed with the correct personality for your application, open KeyLoader and select ZEROIZE Radio. That will wipe out the existing encryption profile. Then you should be able to keyload your Provisional UKEK file.
2wayfreq
NM Kirk City
I Zeroized and Re-Keyloaded. That got rid of the error. Thank You all!!
