Xpr6550
wesley2099
I have a xpr6550 and am looking for some advice. I have auto scan enabled and it is working good however it does not show the channel or talkgroup that is recieving. It only shows the tgid. Is there a way to have the radio show the channel instead of the talkgroup id.
My second issue one of two channels the audio comes in super low when receiving dmr. I have seen the audio leveling option but I am not able to find that setting. Wondering if something In the cps can be adjusted for that one channel.
yaknamedjak
localhost
It sounds like you may need to change the Contact name to the name you want to display for that TGID (Call ID). I believe it will also display the Radio ID of the transmitting radio, assuming this is DMR, so you need to have a Contact defined for that RID if you want it to show their name instead of their Radio ID.
wesley2099
I appreciate the tips. My situation is I’m using my 6550 for a scanner so there are a lot of channels that use say tg10 so trying to keep them separated would be nice. Eventually I will upgrade to something better able to handle it maybe something with digital monitor mode or promiscuous mode would be even better.
K2NEC
5F6
If you have multiple different uses for TG 10 (I.E. Security, Maintenance, Housekeeping) unfortunately you can only name it one thing. Most people opt to just leave it the TG number.
Unfortunately the 6550 isnt really a scanner so its not meant to handle multiple of the same TG numbers
