IP connect??
TSLtrek
Hi,
I'm not well versed in radios, but I am an engineer so I get the tech.
We have 2 geographically seperate locations that we want to be able to connect via the radios.
One site is using HT750s. The other has nothing at this point and will just need a base station.
I saw MOTOTBO IP Site Connect and am wondering if this is a solution for us?
I appreciate the help.
gary123
simplex or duplex?
If simplex then all you would need is antennas to cover the distance between sites.
If duplex I would look into onsite repeaters (VHF or UHF) with a rf link between the sites. I have constructed numerous sites like described. If the sites are far enough apart you can use the same repeater pairs at both locations, this would allow units to travel between sites without needing to change channels.
mikewazowski
Forums Manager
Oot and Aboot
IP Connect will connect two TRBO repeaters together over IP.
You'll need to buy TRBO end user gear and two TRBO repeaters.
TSLtrek
gary123...the sites are 70 miles apart...does that fit your solution? I'll have to check on the sim/dup.
thanks.
Mike, thanks for the info.
RKG
Boston, MA
I'm not sure of exactly what you are asking, but if you want to know if you can back-to-back two stations via IP, take a look at the JPS "NXU-2A" device. You will have some work to do convincing your ISP to provide you with static IP addresses, but apart from that the NXU-2A works like a charm.
