IP Transit Programming Issue Suggestions?
Hello all. I recently put together a Hytera IP Transit setup using a “master” and “slave” radio, both HM782. Both radios are UHF and are using different frequencies in a pair I have licensed for my business. Master is in my truck using Starlink and slave is in my home connected to Comcast internet. Both are using GLinet vpn router. I am also using Hytera HP782 handhelds as part of this setup. I’ve gotten it all to work except one part. When I talk from the slave side it will be heard on the master hm782 mobile. However, it fails to transmit the ip traffic back out as rf traffic. The knob does not turn red indicating it’s transmitting. In reverse it works perfectly so I know what it is supposed to look like.
I can assure you it’s not a talkgroup, timeslot or color code issue. It works in reverse and the master radio does hear the transmission from the slave via ip. I made this graphic to illustrate what works and what doesn’t. It has to be some little setting in the CPS that I am overlooking.
I solved my problem. I’ll leave it here in case anyone else runs into this problem in the future. For IP Transit each radio has to have a radio ID set to 2 or above. I forget the max range, but as I understand it cannot be radio ID 0 or 1. I set radio ID to 3 and it worked. Hope this helps someone some day.
