Ironton PD/Dispatch
Anyone out there have any current info on the Ironton PD and dispatch? I think they are on MARCS P25-1 but I have heard that dispatch is shared with Sheriff department whatever that means. Kind of still new to all of this. Its been well over 12 years since I monitored anything in the area and it all just seems like a mess now haha.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Given that no one local has responded so far I'll weigh in: Having a look at the database I'm not seeing anything on MARCS specifically for Ironton PD but I did find these two talkgroups, wondering if Ironton could be one of the "villages"...
Lawrence County (44)​
280166d70DPD44DSPVillage PDs DispatchLaw Dispatch
280206d74DPD44TC1Village PDs TacticalLaw Tac
There's also a VHF conventional "car to car" frequency which may or may not still be active:
151.235KQA330BMIPD CARIronton Police car to carFMLaw Talk
DanKC8PAE
Butler County
I am not local to your area so I can not answer your question directly on the Ironton Police department. In most of the counties the county sheriffs department takes care of dispatch for the whole county . I live Butler County and our Sheriffs department dispatches most of the law enforcement, fire and emergency medical services for our county. They have the City of Hamilton Police on one talk group and the sheriffs department and all of the small villages and township police departments on another talk group meaning all of those agencies share a primary dispatch channel. I alpha tag the shared dispatch talk group for my a area as Law Primary.
W8UU
Pilot of the Airwaves
Wellston OH
Ironton PD closed their radio room several years ago and the Lawrence County 911 Center (operated by the Sheriff) dispatches them now. The "VILLAGE PD" dispatch has always been for Hanging Rock, Coal Grove, South Point, Chesapeake, Proctorville, and Athalia Police Departments. These are very small departments, some with only one or two part time officers. Back in the old days, the Sheriff's office dispatched county and village units on 39.62 MHz, then later on a repeater system on 154.40 MHz. Ironton PD was always dispatched on a separate channel: 39.76 was the low band IPD frequency for decades, then they operated on 154.800 MHz repeater system when all Lawrence County public safety agencies moved to VHF high band.
The MARCS talk groups remove the Sheriff dispatch from the village dispatch. I'm betting another MARCS talk group exists for Ironton PD (they're a city with a number of officers on the road every shift) and/or they're still using their 154.800 MHz VHF analog repeater system. I do know the repeater is still on the air but I'm not in the area enough to tell you if it's being used regularly.
MARCS has made an absolute mess of interoperability in southeast Ohio. Rural counties, small towns, and townships struggle to find the big dollars for P25 digital trunking radio equipment and never-ending user fees. A number of departments just gave up and are staying with their legacy analog systems. Interoperability is gone because some agencies *did* switch to MARCS and either pulled their analog radios or are letting them fall apart wherever they are located.
I'll see what I can find out when I'm in the Ironton area and post it here. Hopefully, someone closer than I am can jump in here and give you the final answer on Ironton PD.
Thanks for all of your input fellas. Much appreciated. I’m trying to ask around by word of mouth to a few contacts I know in the area but it seems like everything is shrouded in secrecy these days.
Wow a lot of great info here thanks.
W8UU
Wellston OH
Ironton PD is dispatched by Lawrence county sheriff MARCS TG 54817 only. The old 154.8 nfm is no longer in use. Some villages use 154.4 nfm and MARCS
THANK YOU! I was digging through old contacts in the area and didn't get a reply.
red8
denham springs la.
I picked IPD down here in Livingston Parish, La. on the old 39.76 one time. The Livingston Parish ( County, for the rest of the country) had the same frequency as old KQA330. I also remember cars 80,81,82 and 83 were the calls of the units while 85 were the paddy wagon.
W8UU
Wellston OH
That's the dead ringer!
The KQA-330 base station simply identified as Three-O, as in the last two numbers of the FCC call sign. For mobiles, 80 was the Chief, 82 was the traffic enforcement person, and the rest of the numbers 83 through 89 were patrol cruisers. Ironton's officers identified by what car they were in and not by badge number or any personal identification unlike the Sheriff's deputies and village police officers in Lawrence County.
It was neat to hear the dispatcher and cars communicate because, like most Ohio law enforcement agencies, it was a string of spoken analog numbers. "30-84, 30-87" "87-30" "Signal 41, 12th and Lorain" "87, 10-4" "88-30, Two Six" "30-88, OK". Unlike most of Ohio, Ironton did not use the standard BSSA radio codes back in the day but opted to make up their own. With the department on VHF and MARCS now, the unit numbering is different and I'm almost certain they're using BSSA codes.
That's amazing you could hear them in Louisiana. Ironton PD used a 60 watt GE MASTR II base station with a DB 201 folded monopole antenna mounted on a telephone pole on a hill overlooking Ironton and the Ohio River. The antenna was barely above the tree line. The radio was controlled by a dedicated phone line to the dispatch office in the basement of the (city hall) Memorial Building. Mobiles were 60 watt Motorola Mocom 70s and GE MASTR II's. They all had the countywide 100.0 hZ PL tone. The base station only had 39.76 MHz. Mobiles had IPD 39.76 MHz, Sheriff/Village PD 39.62/39.26 MHZ half duplex and 39.62 car-to-car channel, and 39.58 MHz which was Ohio's statewide low band police inter-agency channel at the time.
Four channels in your low band scanner with an outside antenna kept you well informed. Plus, when skip started rolling, there were all kinds of goodies you'd hear from all across the country. Los Angeles County California used 39.76 for one of their agencies (Sheriff?) and the Ironton cops griped about not being able to mark their own dispatcher during hot summer days when LACO was blasting away with one call after another. The good old days!
red8
denham springs la.
It was a clear day and not a cloud in sky . Sometimes of an evening I would hear. I was at the Sheriff's Office in Baton and we were on 39.54 mhz as our main dispatch , we could pick up Cuyahoga Co., Fairfax and several other counties in Virginia PLUS on our alternate channels we were able to pick up several counties out in California. The skip got so bad in 89 we went to 800 mhz trunk system. This was interop with the State Police and Baton Rouge City
