XTL/XTS5000 Is it bricked?
TomWinkel
I've been working on a code plug for my XTS 5000, that I was going to use as a scanner, but when I write the new plug, all I get is dead air, Is it possible the radio is bricked?
KJ4DHF
uhf/vhf 700/800? It's possible it could be as you say"bricked". There is a lot to setting up a radio to do NAS. It could be cp error's.
K2NEC
5F6
If the radio is powered up still, its not bricked.
What exactly are you trying to program and what is "dead air"?
TomWinkel
by dead air, I mean I don't hear anything at all, I'm trying program it as a scanner
ElroyJetson
Just snowballing a few things....are you trying to monitor a Phase 2 system with a Phase 1 radio? (5000 and XTL are Phase 1)
Got the site numbers right? Wrong number, no reception.
Better by far to use a scanner.
If they're encrypted you won't hear a thing.
PARTHCITY
I can't find anywhere in the cps to input NAC
NAC is in the Zone Channel Assignment area. That is, if you set it up as an Astro personality. Could you please give us more info. such as
  1. Model Number of your radio
  2. Flashcode/feature set of your radio
  3. What you are trying to monitor
gary123
Bricked usually refers to a radio that does not respond to CPS or any other programming software.
NAS requires several things to be set correctly. PARTHCITY has a good suggestion. we would need more details on the hardware and system before any meaningful advice can be issued.
PhillyFireFeed
Put that bad boy on FB Marketplace and get something more your speed before you get it ACTUALLY bricked or a visit from the feds...
I hear Uniden has the SDS100 on sale for a whopping 5% off right now :rolleyes:
slobonmycob
I feel sorry for your agency if you’re the support
Most agencies that have access to and use those P25 radios still use scanners.
AEFI
East Valley San Bernardino County
Or even drop the file of your codeplug here
Btw if you do nas and if the system id is not bee00 its probably going to be hard to listen to
TomWinkel
Model: XTS 5000
Flashcode: 589008-101687-0
trying to monitor fire/ems/le on the job to avoid interfering with their work and vice versa
Enjoi19
Ontario, Canada
If you don't want to interfere, get a real scanner. Sorry, but the questions you've asked so far indicate you're in over your head on this one. I'd get some money back on the XTS5K and put it towards a scanner.
TomWinkel
I cant find anywhere in the zone channel area to to input the NAC or Hex codes
