Is RTL SDR v4 supported in Windows 7?
Adjie_Arp
Hi there, i'm newbie here. I'm wondering if i could install SDR software for my RTL SDR v4 in my windows 7 laptop (Intel Celeron with 4gb of RAM)
Is windows 7 still supported for RTL SDR v4?
And what kind of software that you recommend?
dave3825
Suffolk County NY
Adjie_Arp
I'm trying with HDSDR and using Ext io from github
It says that it doesn't recognize my v4 dongle
maus92
OCMD
Windows 7 is a deprecated operating system and should not be used by any computer that connects to the internet. Also, the computer that you are trying to use is low-spec thus may not work satisfactorily with SDR programs. That said, did you read the Windows section in the linked article? Specifically:
"On Windows, updating the driver is usually just a matter of replacing a .dll file with one from our RTL-SDR Blog Driver Release on GitHub. Most software will use the rtlsdr.dll file in the x64 folder, but notably x86 programs like SDR#, welle.io and RTL1090 require the dll from the x86 folder."
If you did the above and the SDR device is still not recognized, you may need to run a program called Zadig which is a free download. Zadig replaces the Windows Realtek device driver with one compatible with SDR software. Be careful to install the replacement drivers to the proper device as Realtek makes different components that could be installed on your computer that have nothing to do with SDRs.
I suggest that you read through these forums as questions like yours have been asked and answered many, many times.
slicerwizard
Toronto, Ontario
Yep, I would think that using Zadig to install the USB driver and then replacing the standard rtlsdr.dll file with the V4 DLL file should be all that's required.
Flyingchip
Zadig has solved all my problems with an old laptop and Windows 8 and I think it can do the same thing with Windows 7
