With "Advanced privacy", is AES256 really necessary? I mean, it would take forever to crack the code, even if you had some way to do it. Basic Privacy with a key of "1" would effectively render scanners useless.
Well considering RC4 uses a 16 bit shorter key space than DESis a weaker cipher than DES, even if the key-space was the same.
DES has been considered owned since the late 90’s you do the math. DES and RC4 will keep scanners out but someone with the right software skills and some processing horse power would likely recover a DES or RC4 key in less time than we would think.
If you want secure conversations AES256 is the cipher you should be using.
‘Enhanced’ privacy will keep scanners out, and that’s it. A determined adversary would set around 40 bit RC4 in little time.
Basic privacy is like PL. There are 255 unique ‘keys’, you could run every key in a matter of minutes with a properly programmed DMR radio.
