Is this Basic, Enhanced or AES Encryption...DMR MOTOTRBO
phantomcrow
Retired LE
The jack is hooked up with a 3.5 and I used DSD to record. Not sure what else to do? Or is there a another way?
phantomcrow
Retired LE
The sound from the scanner is coming through the speakers and thats what I got
slicerwizard
Toronto, Ontario
Did you press R in DSD+ to start and stop recording during an encrypted call? If so, you'll have a short wav file of raw source audio to upload.
phantomcrow
Retired LE
I did not, but I will in the morning thank you for the help I appreciate it
hrh17
Currently, if you want to confirm what flavour of encryption is being used on DMR you need OP25. It will indicate if its
ARC4
DES
AES128
AES256
phantomcrow
Retired LE
ARC4
DES
AES128
AES256
Never knew about this, ty going to try to use it tomorrow looks great
phantomcrow
Retired LE
And here is the raw .wav file. I also included a snapshot of the DSD event log. Can someone tell me anything about this signal? Thank you
  • cut_DSDPlus-Raw-Input_2019-10-30@030936.zip
Forts
Ontario, Canada
There doesn't appear to be any activity whatsoever in that recording.... From your screenshot however you can see the algo in use is predominately EP (I'd hazard a guess that the BP entries might be bad decodes). Still need a good recording to confirm that however.
phantomcrow
Retired LE
Ok Ill work on it further. Does EP mean enhanced Privacy? Because another encrypted state channel uses AES 256 and EP is not present
racingfan360
The wav file doesn't open for me. It would also be good to have some raw audio recordings as well via DSD+ (pressing R key on/off when DSD+ is running to activate/deactivate)
RRR
OFFLINE
USA
So how does one get AES for Mototrbo?
phantomcrow
Retired LE
I am still attempting to do this however, for whatever reasons, having a very difficult time. Also am trying Snooper where I can record the raw audio from the IP discriminator out put via 3.5 cable will keep you posted thank you
Forts
Ontario, Canada
Or by a DMR radio from Hytera or Anytone who will gladly let you have AES. Anytone added it to the 878 for free in their last firmware update.
phantomcrow... With DSD+ running just hit R to begin recording (I believe you will see <REC> at this point in the title bar). Let it run for a while to record some traffic, then upload it to a sharing site like SendSpace. You posted a screenshot of it working before so your setup seems sound. Just need a longer recording.
phantomcrow
Retired LE
It seems to be recording static and the transmission. Ill try again thank you
Forts
Ontario, Canada
That would be normal. Should be static between transmissions and digital noise during the transmission.
