HT1000 Is this the adapter I need to connect an HT1000 to coax?
jaspence
Michigan
The HT1000 antenna does not have a center pin from the picture I have, so that is not the correct connector on the end that screws on. Without knowing what coax, the other end is a BNC female, but it is not possible to give you an answer without knowing how the coax is terminated.
jaspence
Michigan
That BNC will not connect to the PL259. Another picture I checked shows the radio with a center pin connector, so you need to confirm which it has. Do a search on PL259 for the correct connector
thorosaurus
Mine does (DN model). I couldn't speak for all of them.
I was just going to buy coax by the foot from the same website, so I can do whatever connector you guys think is best. I was going to do a compression type BNC connector, unless you guys advise against that for some reason. Trying to keep costs low mainly. Actually, I think I already have some coax cable laying around if I can find it.
thorosaurus
That one may not reach the radios connector properly. And yes you want BNC female as that puts less stress on the radio.
It looks like it would. It looks exactly like the connector on the OEM antenna. I think the SMA adapters that don't work for Motorola are the ones that are recessed.
The antenna connector on top of an HT-1000 (or any of the Jedi radios) is a male SMA. A female SMA will work for making the connection.
Challenge is the spacing between the top of the center pin and the top of the radio can make some connectors problematic. Make sure you get one that is known to work.
Also, you need to be -REALLY- careful with attaching coax to the top of a portable radio. If your set up puts a lot of strain on the connector, it can damage the solder joint where the coax connector mates to the circuit board. Use thin/flexible coaxial cable.
Or better yet, use a mobile radio, like God intended.
FFPM571
Nashvillle
If you are interested I have a factory motorola connector that clips onto the speaker mic port and has a short length of cable that terminates in a Male BNC
thorosaurus
Good point. I ordered a RG174 with BNC connectors. Will also make it easier to do my coil to prevent the coax from becoming an antenna.
thorosaurus
Thanks but I need a female. Coax I went with has a male connector.
