#!/usr/bin/liquidsoap
# Example liquidsoap v2.x streaming from op25 to icecast
# (c) 2019-2024
gnorbury@bondcar.com,
wllmbecks@gmail.com
settings.log.stdout.set(true)
settings.log.file.set(false)
settings.log.file.path.set("/home/op25/op25/op25/gr-op25_repeater/apps/liquidsoap.log")
settings.log.level.set(3)
settings.log.file.append.set(false)
# Make the native sample rate compatible with op25
settings.frame.audio.size.set(8000)
input = input.external.rawaudio(buffer=0.25, channels=2, samplerate=8000, restart_on_error=false, "./audio.py -u 23450 -x 1.25 -s")
# Consider increasing the buffer value on slow systems such as RPi3. e.g. buffer=0.25
# Longer buffer results in less choppy audio but at the expense of increased latency.
# OPTIONAL AUDIO SIGNAL PROCESSING BLOCKS
# Uncomment to enable
# High pass filter
#input = filter.iir.butterworth.high(frequency = 200.0, order = 4, input)
# Low pass filter
#input = filter.iir.butterworth.low(frequency = 3250.0, order = 4, input)
# Compression
input = compress(input, attack = 15.0, gain = 2.0, knee = 1.0, ratio = 3.0, release = 60.0, threshold = -24.0)
# Normalization
input = normalize(input, gain_max = 6.0, gain_min = -6.0, target = -16.0, threshold = -40.0)
# Optimize mp3 audio recording level
mp3_audio = amplify(0.65,input)
# Create infallible local speaker and streaming audio
input_safe = mksafe(input)
# Dump mp3 audio files to Apache web server
output.file(%mp3(stereo=true), "/var/www/html/op25/MPSCS-%Y-%m-%d/hour-%H.mp3", mp3_audio, fallible=true, append=true,
reopen_when={0m})
# LOCAL AUDIO OUTPUT
# Uncomment the appropriate line below to enable local sound
# Default audio subsystem
#out (input_safe)
# PulseAudio
output.pulseaudio(input_safe)
# ALSA
#output.alsa(input_safe)
# ICECAST STREAMING
# Uncomment to enable output to an icecast server
# Change the "host", "password", and "mount" strings appropriately first!
# For metadata to work properly, the host address given here MUST MATCH the address in op25's meta.json file
output.icecast(%mp3(bitrate=16, samplerate=22050, stereo=false), description="OP25", genre="Public Safety",
url="", fallible=false, icy_metadata="false", host="localhost", port=8000, mount="op25", password="hackme", mean(input_safe))
