Issues with servers?
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
audio3 was locked up at about 3am, and I didn't get the notification until I rolled out of bed this morning.
All should be well now. Thanks for your patience.
AB4BF
EM93cs
I'm sure this is just a temporary issue but one of my feeds just went down and here's the error I'm getting. Posting this here in case other people run into the same issue and wonder what's going on. My feeds on audio1 and audio9 appear to be just fine.
23-Oct-2021 04:32:32 Connecting to Icecast server audio3.broadcastify.com/ 23-Oct-2021 04:32:53 Connect to Icecast server audio3.broadcastify.com/ failed: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 23-Oct-2021 04:32:53 Attempting connect on alternate port 8000 23-Oct-2021 04:33:03 Failed to get reply from Icecast server audio3.broadcastify.com: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 23-Oct-2021 04:33:28 Silently continuing to retry contact (103). 23-Oct-2021 04:33:49 Failed to get reply from Icecast server audio3.broadcastify.com/: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 23-Oct-2021 04:34:19 Failed to get reply from Icecast server audio3.broadcastify.com/: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
I'm not a Broadcastify provider nor user, but I was having connection problems a little last week and a lot this last weekend. I could not access some websites that I normally have no problem with. I kept running troubleshooting guides and this finally popped up: Fix DNS Problem. A Domain Name System (DNS) allows a site IP address (XXX.XXX.x.x) to be identified with words (*.com) in order to be remembered more easily, like a phonebook for websites. This service is usually provided by your ISP.
Clear your local DNS cache to make sure that you grab the most recent cache that your ISP has. For Windows - (Start > Command Prompt > type "ipconfig /flushdns" and hit enter (without the quotations)). For details choose your operating system.
I did this and it was like magic. So far, I haven't had any more website loading problems. I also had to perform this on my laptop and my wife's laptop. Worked there, too.
I do not know if it will work on voice providers, YMMV. I thought it was interesting that Broadcastify was having basically the same problems - not able to connect to some websites.
