Itinerant License
otobmark
NC
Youth organization reached out to me about comms/radios for use during their multiple summer camps. I have requested much more information but for now what I know is that they lease camp campuses by the week (they don’t own properties themselves), need several mile (?) coverage, poor cellular, FRS was a fail and locations may change year to year. I welcome equipment thoughts though for the moment I’m focused on licensing issues for what will surely be an itinerant situation. I’m far removed from the business side of LMR and licensing. What is available? I’d prefer digital for many reasons and portable repeater(s) would seem unavoidable. ( I do wonder if camp owners would be interested in having a system themselves?)
So, itinerant repeated digital.
For a “not year round” use I’m not sure they should be buying. They have school year events which could benefit from simplex comms probably. Obviously they don’t have “government “ size money (I might donate the system if my modeling career doesn’t tank😐).
tweiss3
Is it time for Coffee?
Ohio
NXR-1800E and NX-1800 are pretty darn affordable. I'm certain a year's rental costs would be darn close, if not exceed a rental from some of the bigger guys.
dryfb
America
I was gonna say NX1300s for portables lol, or 1200s if VHF would work better.
Digital is fine on itinerants, and there are repeated itinerants (afaik, if not correct me). I think there's a class (like FB2 type of class) for VRSs so you could possibly get a coordinated license that covers what you need but itinerants would probably be cheaper.
tweiss3
Ohio
I don't believe there is Itinerant VHF usage, I do remember reading 2W ht, 5W repeater itinerant pairs.
Project25_MASTR
Millennial Graying OBT Guy
Texas
I have itinerant pairs on both VHF and UHF. VHF isn't common to see that so it tends to be fairly uncontested unlike 464.0000 and 464.5000. So I would say a NXDN VHF solution would be pretty good. If the facility has a ropes course, that would be a pretty prime location for a simple tactical repeater system.
tweiss3
Ohio
Yes, you can license VHF for itinerant use. It’s quite common in my region.
I should re-read what I'm typing up. I meant VHF itinerant repeater pairs like the 47 CFR 90.267(f)(5) uncoordinated nationwide UHF repeater pairs.
Yes, if you are going repeaters, UHF, if not VHF.
I've been running some NXR-1800's for about 6 months now at a very remote site, and I'm really happy with them. The remote access web interface is pretty nice since I can check the system without making the 3+ hour drive to the site. With a reliable IP connection, you can link repeaters. Build the repeaters in a fly away case so they can move them around as needed. Plug-n-play as long as they don't knock the duplexers too far out of alignment.
Been using the NX-1300's for about 2 years now, and they are working well. Price is right for applications where the end user may not be as careful with the radio as they should be.
Sounds like the right application for itinerant frequencies.
I'd talk to the camp owners and see if a shared cost would make sense. But permanent and itinerant really don't jive.
otobmark
NC
So the answer is yes, it can be done. I figured if NASCAR and PGA can roam the country with extensive setups then it must be possible but at what cost/difficulty. If limited to 5 watts for subscribers and repeaters it would be possible if not ideal. Most camps are rural, at least here in the south. Linked field repeaters would be nice and could be done by RF (ubiquity, beamed wifi etc). I had a cashe of FRS radios for command center use (we use apps on wifi networks now) that I loaned out to a similar group of radio ignorant volunteers and staff and they came back looking like they had been through fire and explosions. I couldn't imagine the contempt shown them. I had no real future use for them so I wasn't really "OUT" so much as bewildered by what happened to the gear and the mentality behind it. Public safety is only marginally better, especially with vehicles. I'd like to tether the gear to a locked on collar so when they mistreated it they would get a few thousand volts! I come from a generation that took better care of other's stuff than out own.
I will reappear here when I have more information (budget, number of radios, terrain etc). I'll investigate NX1800 and others.
Good info all! Thanks for not ridiculing my blind spot..
I've got some UHF itinerants at work, and they are 35 watts. If all you are using is 5 watt portables, then a 10 watt repeater would be plenty. As you know, the antenna makes a bigger difference than the power.
NXR-1800 is the repeater. You can get them analog only pretty cheap. Or, you can add NXDN -or- DMR. IP linking is an extra cost option. Mine are on mountain tops, solar powered, and due to space constraints, flat pack duplexers. At 10 watts, they pull a bit over 4 amps on TX and about 700ma on idle.
NX-1800 is a mobile.
NX-1300 is the portable
Mobiles and portables can be purchased as analog only, analog + NXDN or analog + DMR. Since it sounds like this won't have much traffic, 6.25KHz NXDN would give you a bit more range.
