Jackson
WolfmoonX
Cleveland, OH
I dont think Jackson has a trunked system kbadler.
Not sure if this is allowed but here are the regular frequencies for Jackson. (non-trunked)
As listed in 2003 Police Call.
Jackson Police (Dispatch) 500.9125
501.2875
503.9125
504.2875
460.2375
460.4625
465.2375
465.4625
Jackson Fire Co. #1 33.8000
Jackson First Aid 155.2050
155.2350
155.2800
Jackson Gov. 158.7450
453.4750
458.4375
458.4750
Hope this helps. Wolf....out
stevpiz
new jersey shore
jackson trs
I think they may use the ocean county system as I have heard some locations mentioned in the jackson area
WolfmoonX
Cleveland, OH
I get alot of Jackson's local stuff on the above mentioned frequencies. The only reference to the Ocean Co. System that would be near there would be ID: "Plumstead" right?? Out of curiosity....I wonder why there isnt an ID for Jackson Township?
601
Harnett County, NC
Jackson Township doesn't use any type of trunking. The 460 MHz frequencies are used for some sort of "rebroadcast" of police comms. I have yet to hear any oter type of comms on those channels. The only trunked systems that I know of around this area are Ocean County Sheriffs Department in the 506 MHz area.
Jackson no w also has 1 800 MHz frequency for the MUA
Tech792
Central NJ
Jackson Fire
According to an inside source, Jackson Twp DID switch to a trunking system. From what I hear its just for fire dept use now. The newly licensed trunked frequencies are listed below. I'm still waiting for more info regarding this system.
506.5875
507.0875
507.3375 Dispatch/Alerting
Apparently they no longer tone out on 33.80, nor do they use it for fireground comms any longer.
But tone out on 507.3375.....
fire ops is supposedly trunked.
I'm getting all this info second hand and just passing it on.
The above frequencies are licensed as trunked channels on the FCCs data base. But wheather they are being used as trunked is another story.
Maybe some one in the Jackson area can try those new frequencies out and see what they hear. Since I'm a little out of the area.
Pete
Tech792
rickey456
North Brunswick NJ
Jackson trunk
Took a ride and sat on a side street off County Line Road right off of US9. I monitored all of the listed 500MHz frequencies and looked for a control channel or other activity.
For the hour that I monitored, none of the listed frequencies was a control channel or a data channel. Only one frequency, 507.3375, was keyed during this time. I did not hear any voice comms of these frequnecies- but that's not unusual if there was no fire traffic.
The only control channel of any sort that I could receive from that location in the car was 508.4375 which is 5c3f- the Ocean County system. There was a considerable amount of EMS traffic in and around Dover Twp.
If Jackson is indeed trunked, it was either not turned on or in use during the time I monitored the frequencies.
Rickey Stein
Tech792
Central NJ
There is a possibility this is an LTR system. If it is, that would explain why we're not hearing a control channel.
Pete
Tech792
stevpiz
new jersey shore
jackson
listening to this system tonite resulted in hearing no active traffic channels, but every once in a while do hear the squelch breaking with a short transmission like the system is perhaps being tested.
saw these LTR readings but could have been due to noise
0 00 69
0 00 74
0 00 82
0 00 94
0 00 154
0 00 167
0 00 185
also saw a readout for LCN 05
Tech792
Central NJ
Jackson Twp
The short transmissions/key-ups approx every 30 seconds are charactoristics of an LTR trunked system.
And I'm told the fire dept is the only user. (At least right now). That would explain the in-activity.
stevpiz
new jersey shore
jackson
this is a link to LTR system info on this site and you can also see one at http://www.optoelectronics.com/tech/pdf/ltr_faq.pdf
the activity was detected on the first frequency in the TRS DB but heard bursts on all channels
you can decode LTR with old PRO series scanners (evidently the older version had LTR but the newer ones dont), with the Optocom Optotrackker (http://optoelectronics.com/ but no longer made) but you can see info on it here at http://www.durhamradio.com/optotrakker.htm
it also does DTMF, DCS, CTCSS and moto and doesnt require a PC to work, it wouldnt be a bad thing to have around if you can find one on ebay cheap
RADIOGUY2002
Chicago Burbs
Thanks Steve
Yea, I would agree that its an LTR system the re-keying is a dead give away. Fire depts are the hardest to pick off because message are short and to the point. Dont now how fast the city in question is to see if lots of radio traffic would exist or not. The systems out here by me are consstant and never stop guess im lucky like that. But theres an ltr system out here thats throwing me for a loop, they have got be the hardest to stay with, control channel are so much nicer. But then your talk about a 1,ooo or more add to the setup costs. Just thought I drop in and say thanks to steve as well as on your ltr system that like to throw all of us for a loop at times.
stevpiz
new jersey shore
jackson
there is no traffic on this system yet as I can monitor all the freq's and would hear the voice no matter how short the messages are.
think they are either testing or system isnt up yet or my optotracker has given me bad data from noise
RADIOGUY2002
Chicago Burbs
Traffic Activity
Well either way keep me updated, and once again thanks for the link. The system will eventually come out and word will travel fast. Till then its up to us to attempt to firgure it out
Take Care Guys
stevpiz
new jersey shore
active LTR heard in central NJ
anybody near jackson that wants to hear what an LTR system sounds like can tune to a pretty active one on 461.05 which is a car service on SI NY that can be heard in most of central NJ or the homan LTR system on the western part of the state and you can freq from the TRS DB
ka2mek
I Think WOLF and 601 are right so far,and I don't think Jackson has any trunking system yet.I see AND here ALOT of speculation around but (I heard this ....somebody said that....this guy read this... blah blah blah)Sorry,NO HARD FACTS YET.
(WOLF-E>mail me)
Dr. Rob-KA2MEK
