Jefferson County
154600
I’m trying to monitor Jefferson counties dmr system. I’ve tried the new dmr system in the db as well as the old system. I’m not sure if the info is correct because I haven’t heard anything on either for 24 hours straight. Can anyone confirm if it’s correct?
tvengr
Well Known Member
Baltimore County, MD
Do you have the LCN and color code for each frequency in each of the 3 sites? Which scanner and software are you using? Does your scanner have the DMR upgrade if applicable? Please attach your programming file so we can take a look at it.
154600
I think I figured out the problem. I appreciate the responses.
