jpole antenna
kf5rqk
can a jpole antenna be mounted to a metal pole and how high in the air is sufficient,
thanks
ko6jw_2
Santa Ynez, CA
Yes it can be mounted on a metal pole. It should be high enough to be clear of obstructions. The higher the better.
W4FLP
How can you (or should you not?) mount two vertically polarized antennas on the same mast? I have a specialized 70cm vertically polarized antenna on top of a mast and would like to add a 2m J-pole but am not sure that will work to be so close to the other antenna? Thanks.
nd5y
Wichita Falls, TX
You can't mount a j-pole up against a mast. If you don't want to move the existing top mounted antenna then the easiest thing is to add a cross arm or bracket that is at least 1/4 wavelength long and mount a vertical dipole on the end so it is at least 1/4 wavelength from the mast.
W4FLP
So ballpark would be that it would need to be 234/ 140 (MHz) = 1.67 ft away from the mast? Maybe round up to about 2' ?
prcguy
I would go a minimum of 1/2 wavelength and preferably more. At 1/4 wavelength from the mast you will be making it into a 2 element beam with gain away from the mast and a null toward the back of the mast. At 1/2 wavelength it will have a clover leaf pattern with four gain lobes and four nulls. At one wavelength away from the mast you will have eight gain lobes and eight nulls but they will begin to mellow out and be more omni directional.
This is the age old problem for commercial tower owners trying to fit more antennas and revenue on the tower.
W4FLP
Well... ok.... maybe I'll take it over to the chimney which is about 25' away ;)
