Jughead8152
JUGHEAD8152
I need to reset my 1098 to the factory defaults. How do I do this. I was trying to do a limited scan and also get my computer to recognize my scanner and got it all screwed up. REALLY screwed up. The only hope is to do a reset! Thanks
Swipesy
Northern Ohio
General Settings Tab of EZScan click on Restore to Factory defaults and then copy configuratiin to SDCard.
TAbirdman
MO
on the unit. main menu, Set location, Select "Clear Channels"
JUGHEAD8152
I finally got the driver instaled. The EZscan still doesn't recognize the scanner. I also can't do a cpu update. Also on the scanner I can't do a limited search.
JUGHEAD8152
Thanks I will try this. I have a new computer coming Wed this may fix my problems.
TAbirdman
MO
Go into your device manager . If the scanner doesn't show up in the DISK Drives location, you have a USB port or a USB cable issue.
