dcisive
Saw an add for a Ebay seller who is a Ham radio operator and has been designing and building antennas for many years. Saw his complete run down and explanation of his design and what it would accomplish. I bit on it. I cut and pasted his schpiel so you'd know what it was all about. Gotta tell ya I'm getting tons of stuff I never heard before let alone the fact it's coming in nearly full strength most of the time. Airport stuff which is 30 miles from me comes in like it's around the corner. Before it typically didn't come in at all. That's in the 124-125 range. The 400-460 range is so strong now I'd say the signal to noise ratio went from decent to dead quiet, at least a 3db change. What a pleasure now to listen to most of the broadcasts. 800mhz stuff is strong and dead quiet as well. I took it and with tie wraps mounted it on an upright fixed mic stand I had but was never using anymore. Placed it in the end of my closet which faces an outdoor facing wall. Raised it to the ceiling. Ran it's provided RG8X cable along my base board behind my desk so I don't have to see any cable but it's sure doing a fine job. Here's the blurb that was on Ebay when I bought it. Highly recommended. Some of the better $50 investments I've made. here is his advert.
SUPER SCANNER TWO BASE ANTENNA
Up for sale is a totally new Scanner base antenna that covers reception from 28 mhz. thru 1200MHZ from well known Antenna designer Lowbander. It works with all modes: Analog or Digital transmissions. Great for Listening to Trunking Systems!
The Super Scanner Two has 4 separate elements inside the plastic tube so users will get maximum single band resonant frequency performance with the highest signal strength. This is a features many antennas on Ebay do not have!
BEWARE OF SCANNER ANTENNAS THAT ARE UNDER 19” IN LENGTH! USUALLY THEY WILL BE NOTHING MORE THAN RUBBER DUCKIES JUST STUCK INSIDE A PVC TUBE!
Buyers should also BEWARE scanner antennas here on Ebay which are fed with RG-59 coax!!! Same for RG-6 coax, both are a 75 ohm coax and all scanners have a 50 Ohm input impedance! Using RG-59 or RG-6 coax creatures built in signal loss from mismatched coax. Comparisions to RG-58 are meaningless!!!
This is why I use high quality , low loss RG-8X coax, which is 50 Ohm coax. This is especially important on the UHF bands. No lost signal strength from my antennas!
The Super Scanner Two is guaranteed to hear better than the telescoping rod antenna that comes with most base scanners!
It has a single element for reception on the 28mhz-220 Mhz range(This includes CB channels, the Aircraft frequencies, 2 Meter Ham, Fire and Law enforcement frequencies), another element for the 400-500 MHZ range(This includes Ham, Fire, Police, local government frequencies), a third element for the 800-900 MHZ band, (This is the new popular Law Enforcement & Fire frequencies, Cell phone bandsand ham bands) and a fourth element for the 1200 MHZ. band(Mostly Ham and some Law Enforcement frequencies). Each element is carefully tuned for maximum signal reception so the antenna performs like 4 separate mono band antennas. A ground plane element for each band is enclosed in the PVC tube and completes the antenna. Many scanner antennas sold on Ebay never mention the groundplane, because their antenna does NOT have a built in groundplane, which seriously affects the performance. The Super Scanner One has 4 separate groundplanes, one for each of the 4 separate antennas!!
Enclosed in a sealed PVC tube, the antenna is a waterproof unit for outdoor use in any weather conditions. It is approximately 34" in length.
The Super Scanner Two Antenna comes with a 20 foot length of low loss, RG-8x coax , of high quality, which means excellent performance and more signal to your radio! It has a standard BNC connector on the coax to plug directly into almost all base scanners.
FYI:
Scanner users should understand that the VHF/UHF radio signals transmitted by police, fire, govt., public service agencies, and ham repeaters are mostly line of sight signals. . Scanner listeners in mountainous areas may have serious problems this factor. This means if your home is in a valley or location that is in a low spot, geographic terrain (hills and mountains) will block your reception of signals. This is true for ALL ANTENNAS, unless you install an antenna high enough to see over the low areas, your reception will be limited by these natural features. Height above ground is the most important feature of a good antenna installation. It might be smart to consider the same antenna but with the 50’ of coax so it can be raised higher in the air. Beware of Ebay Sellers who don’t mention this and just brag about their antennas. Honesty in selling is important and Lowbander has always followed this practice
* ALL BNC COAX CONNECTORS ARE SOLDERED!! NO CHEAP CRIMP or TWIST ON CONNECTORS HERE!!
Just like all VHF-UHF antennas, the Super Scanner Two Antenna works best at the highest height you can install it. This model of Super Scanner Two is designed for mast/ tower installation. It has the same antennas inside as the Super Scanner One Antenna which is also sold on Ebay. See the pictures below on how the antenna is attached to the mast/tower. Stainless steel hose clamps are used to secure the antenna to the mast/tower. These clamps are NOT included with the antenna because everybody’s installation is unique to their location. This cheap hose clamps can be purchased from Lowes/ Home Depot or just about any hardware store. Automotive stores also sell these as radiator hose clamps.
The Super Scanner Two is an easy installation. If you can turn a screw driver you can install this antenna! A recent customer sent this picture(last picture above) over of how he installed the Super Ham/Scanner 3 at his QTH. All he added was a short piece of mast(not included in the auction) and attached the antenna with hose clamps as recommended. Great results were reported with this set up and shows any easy way to install it!
SPECIAL LINKS ARE INCLUDED IN THE INSTRUCTIONS TO SCANNER DATA BASE FREQUENCIES LISTS!!!
Instructions for installation will be sent to buyers in a PDF format at the end of the auction.
The Super Scanner Two Antenna is shipped via Priority Mail in a special tube. Orders go out the next business day! Flat rate shipping of $13.45.
DON'T FORGET TO CHECK OUT MY OTHER SCANNER ANTENNAS ON EBAY!!MANY BUYERS PURCHASE THIS ANTENNA AND FIND OUT LATER THEY NEED MORE COAX LEAD IN CABLE. THE SAME ANTENNA IS AVAILABLE ON EBAY WITH A 50' LENGTH OF COAX. CHECK OUT MY OTHER ANTENNAS.
Lowbander has been making and selling antennas on Ebay since 1999, and is a trusted name on Ebay. He has been making Ham antennas for over 50 years! With a FCC Amateur Extra Class license, Lowbander built his first antenna in 1961! Quality you can trust!
FYI:
