Long-time ham here, off air for a while, trying to re-enter. I previously owned a Kantronics KPC-3 (pre-plus version) and a modest packet setup, had a bit of activity. I just purchased a used KPC-3+, version 8.2 (I think) firmware. Did a "RESTORE", got MYCALL and a few other basic parameters set successfully. Interacting with the TNC in "Command" mode seems all normal. Then, per manual I had downloaded, I tried connecting to my PBBS. Sent CONNECT (mycall) command, CON LED comes on, but no "welcome" message as described in the manual. I then tried a couple of PBBS commands, absolutely no response. Cntl-C brought back cmd: prompt, I sent DISCONNE, Con LED went out.
Also - thinking I could just "read the mail" and see some packet traffic, from the cmd: prompt I set MONITOR ON. Rcv LED flashes occasionally, but no text appears.
For context - KPC-3+ connected via a USB to RS-232 adapter to an iMac running Monterrey 12.7.6 with a third-party app, "Serial" as terminal software. (Could not get the native terminal app to consistently recognize the external port with the adapter.)
It seems to me that everything working OK in "command" mode indicates that I have RS-232 comms set up correctly, or at least acceptably. Is there some subtle parameter setting in the KPC-3+ that I've missed, or did I manage to purchase a broken TNC? Thanks in advance for any insight or suggestions!
DE W7LEJ (Marty)
DE W7LEJ (Marty)
