ProScan: Keep getting this Error
Ishmole
Walden, NY
Unable To Locate The Sentinel profile.cfg Folder To Retrieve Display Colors
Try Again
I have had no luck. Help!
ProScan
Software Provider
Ontario, Calif.
Go to the Options -> Scanner Specific tab. Look for the options Display Color Mode and Sentinel profile.cfg File Location. Change them accordingly.
It will help on issues if you could advise on the scanner type and ProScan version at least.
Ishmole
Walden, NY
Thank you for the quick answer! I am using the software for a BCD992P2. The option SSentinel Profile.cfg is greyed out on my computer. What am I doing wrong?
GTR8000
NY/NJ Database Guy
BEE00
That only applies to SDS series scanners.
ProScan
Software Provider
Ontario, Calif.
What ProScan version are you using?
ProScan
Software Provider
Ontario, Calif.
Sorry. Version 16.1 I should have posted it at first!
Can you double and triple check you are using ver. 16.1 and not SDSx00 type scanner selected. It's impossible for that message to show using 996P2 and version 16.1.
