Kenwood Encryption compatible with DES-XL
kb0wsw
Upper Midwest
Is anyone able to tell me if the Kenwood P25 radios are compatible with DES-XL encryption? Looking specifically at the VP-5000/6000 series and the TK-5000 series. A call to Kenwood said "Maybe, maybe not as I am not familiar with the XL". All of the product info I can find mentions the DES or OFB portion, but not the XL specifically.
Currently using APX-6000 and XTL-5000 but these recently became available as well.
Thanks.
kd4efm
EL98 Florida
The short answer is it will work with the APX and XTL in DES mode.
1 DES-OFB is the standard, DES-XL was M's way to enhance the ANALOG use of it. Digital is just DES.
2 if your using it in the ham bands, be cautious!
3 if you are using it on part 95 and not ham band, have at it.
Direct from JVC-Kenwood LMR, as I am typing this. (I have good sources)
Evans
kb0wsw
Upper Midwest
No, this is for commercial use.
We already use it in the APX and XTL radios, just no one was able to tell me if the Kenwood/Johnsons would do it.
kd4efm
EL98 Florida
I am told it will work with the APX./XTL's.
Dump a code in it and try it, do you have the 5000 and KPG-D1 yet?
*NOTE: I have tested my UHF 5300K6 with an XTS3000 and and APX6000 simplex with
DES (nothing fancy) and works like a charm.
MY DES TEST CODE:
NAME: P25 DES Alpha
KEYID: 13
KEY DATA: 0110203140516170
kd4efm
EL98 Florida
DES-XL is a Motorola variant of the US Gov't DES algorithm.
DVP and DES are self-synchronizing modes of operation, coverage range is slightly degraded due to Rayleigh fading on radio channel.
DVP-XL, DVI-XL, DES-XL use a sync header and periodic sync updates. For operation on fading radio channels, this provides encryption coverage range similar to analog voice coverage.
2-Way Encryption Primer
sfd119
Yes, DES will work. County SO uses Motorolas with DES-XL/OFB and our Kenwoods with the DES works fine with it and the KVL.
