IC-R15 - First Impressions
randybcd396t
Los Angeles
For RT-Systems, this is my understanding.
RT-Systems Licensing Info:
• RT-Systems usually sells one license per radio, which is typically tied to a specific radio’s serial cable or software key.
• You’re allowed to install the software on more than one computer, as long as it’s for your personal use with the same radio.
• You cannot use the same license on multiple computers simultaneously if it’s for different people/radios (unless you buy additional licenses).
The install process is based on a key that is provided when you do the download or order a disc. There is not a different install process other than where you get the software (e.g. download or disc).
I suggest you contact RT-Systems to confirm if you can use one license for the 2 installs. You could do email or call them up. They are very helpful and easy to work with. Just explain your use case and ask if one license is sufficient.
I cannot speak to Butel software.
Xray
Heres a quick ARC15 file of the basic nationwide air frequencies listed on the RR import. Make sure to set the R15 for SD Card Mode to write from ARC15 to the radio. MENU>SET>FUNCTION>USB Connect>SD Card Mode. Then use the SD card menu to import within the R15. MENU>SET>Import/Export>Import>Memory CH>ALL>(filename).
Thanks I'll give it a try, I really need to learn custom programming though. I managed to write a file to the scanner with my local airports freqs, scanner then wanted to restart to load it, so I did. Then it was another process, not sure what, to run the file, but the freqs I programmed were scanning so I am happy about that.
Need to get to a point where I have 5 banks, say 0 through 4, with 3 airfields and 1 bank for blue angels and the other for thunderbirds, and easily switch and link between them. Even though I wrote all the freqs in bank 0, these freqs are not actually showing up or selectable as bank 0. Right now it is cluttered up with Frankfurt, Heathrow and a bunch of stuff I will never use, don't see it in the program software but I need to get rid of them.
Does anyone know:
* Scanner when connected to the computer says "Never turn off scanner or unplug USB" ,, So what exactly are you supposed to do when you are done programming ? There is no dismount option that I can see, so I have just been unplugging the USB when I'm done.
* Any antennas superior to stock ? Haven't used this one enough to gauge performance or compare it to anything else.
sparklehorse
Portland, Oregon
RT Systems vs. Butel for the IC-R15:
Can anyone comment on which is the better software? Are they both able to download from RadioReference? Are they both able to export to an Excel file? Read from an Excel file? Thanks for the help!
Looking forward to using the R15 when it arrives tomorrow.
Gordon
DudleyG
Lexington, Ky
I use RT Systems Software for my R15, but I have used Butel Software for Uniden Scanners and AOR Receivers.
RT Systems can not directly import from Radio Reference but Butel can if you are a Premium Subscriber like you are. RT Systems can import "CSV" files but what Radio Reference provides as a downloaded "CSV" file is not in the correct order to import (the fields are in the wrong order) where Butel takes the RR data and reorders it to the correct left to right order to import into the R15.
The R15 imports "CSV" files and exports "CSV" that you can "edit" with Excel.
The biggest difference in the two software packages is --- RT System Software programs the entire receiver (system setting and memory values) by using the "Cloning" feature built into the R15. Butel only manages the memory values and treats the R15 as a USB device and doesn't do anything with the setting such as Delay and Hold times, screen parameters, etc. (you have to manually enter those settings but Butel doesn't overwrite any of them).
Added - both packages using the programming / charging cable that comes with the R15 (no priority cable required).
I see you have an ICOM R75. The R15 CSV file is in a different order (left to right) versus any other ICOM receivers (such as the ICOM R30 that I have) so if you export from the R75, you will have to "reorder" the file from left to right PLUS add several new fields the other ICOM receiver don't have. (Take some Excel skills).
sparklehorse
Portland, Oregon
Thats very helpful info, thank you much.
sparklehorse
Portland, Oregon
Question, does the Butel software handle alpha tags for the memories? Or does it just handle the numeric data such as frequency, CTCSS tones, step values, etc. TIA.
aprilexe
It has an alpha tag field plus group and category names. The only thing I can’t find in the program is the skip memory list. Most of his demos run 30 days with full features on some of them .
KD9KSO
Midwest
Has anyone else noticed that when you stop a scan on a frequency of interest and then restart the scan in the same group, the radio jumps to the next group and scans that instead?
This is damn annoying as you have to use the arrow pad to back up to the group you were scanning.
k4fv
Dania Beach, FL
I believe that pressing the arrow in your scenario advances scan to the next group within a category. Try putting the group your scanning in its own category.
rocky28965
Otago, NZ
Just looking at a R15 on eBay from Japan.
Very well priced but I noticed in one of the pics, some Japanese or Chinese figures on the screen.
Would that suggest the menus might be in that language too.
xms3200
Cleveland, Ohio
Yes. it will have the Japanese language as well as English. it is easy to switch to English from the menu, just remember, if you happen to reset all the settings back to factory, it will go back to Japanese and you will have to switch again, not a big deal at all. I bought an Icom IC-705 from eBay Japan and learned the hard way. Great radio however.
randybcd396t
Los Angeles
You can't always trust the internet, but this may be helpful to you.
The ICOM IC-R15 is a handheld wideband receiver, and like many Japanese electronics, it can come in different versions depending on the market—specifically Japan Domestic Market (JDM) vs. Export/US version.
Here’s a breakdown of the key differences between the Japan and US versions of the ICOM IC-R15:
🔑 1. Frequency Coverage
• Japan version (JDM):
May have frequency restrictions due to Japanese radio laws. Certain frequency bands, especially those used for police, emergency services, or amateur radio without a license, might be blocked or attenuated.
• US version:
Typically has broader frequency coverage, especially in the VHF/UHF bands commonly used in the US for public safety, aviation, and amateur radio.
🔑 2. Language & Menus
• Japan version:
Menus and manual may be entirely in Japanese. Firmware could also be locked to Japanese only, making it less user-friendly for non-Japanese speakers.
• US version:
Comes with English menus, firmware, and documentation.
🔑 3. Preprogrammed Memory / Band Plan
• Japan version:
May include Japanese-specific band plans or preprogrammed channels relevant to Japan (e.g., Japan’s specific FM broadcast band or local rail/aviation).
• US version:
Band plan and presets align with North American usage (e.g., 88–108 MHz FM band, NOAA weather frequencies, etc.).
🔑 4. Warranty & Support
• Japan version:
No warranty or support from Icom America. Service must be done in Japan.
• US version:
Warranty coverage through Icom America and authorized US dealers.
🔑 5. Power Adapter & Accessories
• Japan version:
Wall chargers or power adapters may be 100V-only and have Type A plugs (used in Japan). Accessories may differ slightly.
• US version:
Charger supports 120V, US plug, and may include US-specific accessories.
🔑 6. Price and Availability
• Japan version:
Often cheaper via importers, but with limitations mentioned above.
• US version:
Slightly more expensive, but with English support, local service, and no band limitations.
Here’s a detailed comparison between the Japan/JDM version and the US version of the ICOM IC‑R15:
1. Frequency Coverage & Band Restrictions 📡
• Japan version:
• Covers 76–500 MHz in AM/FM/WFM mode  .
• Includes broadcast FM down to 76 MHz, but contains small gaps in the 108–500 MHz range due to Japanese filtering .
• US version:
• Covers 108–500 MHz plus standard broadcast FM 88–108 MHz ().
• Includes NOAA weather channels (162.4–162.55 MHz) preprogrammed .
2. Broadcast FM & Weather Frequencies
• Japan version:
• Wide broadcast FM coverage (76–108 MHz), but no NOAA weather support.
• US version:
• FM coverage starts at 88 MHz and includes pre-loaded NOAA Weather Radio channels (~162–163 MHz) .
3. Firmware & Menu Language
• Japan version:
• Comes with Japanese menus/firmware.
• Can revert to Japanese after factory resets; some hobbyists report workarounds .
• US version:
• Ships with English menus, clearly tailored for North American users—for example, NOAA support.
4. Pre-programmed Memory & Band Plan
• Japan version:
• Includes Japanese-specific presets (e.g., FM starting at 76 MHz, Japanese railway and broadcast channels).
• US version:
• Ships with North American presets, including aviation, marine, amateur, and NOAA weather.
JASII
Memory Capacity
I am giving the IC-R15 some consideration.
It looks like I can choose from US or Japanese versions.
The software choices for programming the Icom IC-R15 receiver are RT Systems WCS-R15 and Butel ARC-R15.
Is the Icom CS-R15 readily available in the United States, too?
xms3200
Cleveland, Ohio
If you choose the Japanese version and you do a total reset of the radio from the menu, it will default back to Japanese, you have to take screen shots on how to revert back to English. I learnt this the hard way from my Icom IC-705 which I got off ebay, brand new from Japan. I use it for VHF air, desktop.
eorange
♦RF Enabled Member♦
Cleveland, OH
Japanese versions generally block valid U.S. frequency bands. Check the specs before you buy.
rmiles
Actually, I have a request: could someone send me a copy of the memory channel file installed in the radio? I forgot to capture it and nuked it when I installed mine, and neither of the manuals shows the format of the .csv files for this model. Thank you.
I need this as well. Just picked my R15 up from HRO yesterday and the memory is blank. I need the preloaded stuff.
DudleyG
Lexington, Ky
Here is a screen shot of an exported CSV file that I use in the R15, the forum won't let me send or post a CSV file
DudleyG
Lexington, Ky
The above picture is an export from RT Systems and won't work if you copy it to the microSD in the R15, here is an export directly from the R15 to the microSD card in the receiver itself and then opened in Excel
2006walt
The Villages, FL
Given the likely ICOM price changes soon (in the USA), is the R15 considered a superior radio? I haven't seen any recent reviews (in last few months). The other option is Uniden BCD160DN or BCD260DN. Seems like Uniden offer a much better value and more functionality, DMR and NXDN.
What am I missing that make the R15 superior? Bluetooth is not that important to me. It would be nice if the R15 offers band scope and DMR (not aware ICOM plans a firmware upgrade). Thanks
