Kenwood NX-5000 dual-mode P25/NXDN radios
N2DLX
Hamilton, NJ
I had to send mine back for a PTT issue. The PTT line stopped working including for programming. I'm thinking maybe there's an issue with the ribbon cable between the head and body, so perhaps you have a similar issue affecting the power button line?
Great radios, though. I'm very happy with the mobile and will add P25 and other options in time. Beats Motorola's pricing. I'm normally an Icom person but Kenwood has the better product at this point, hands down.
Colton25
I already had to send it in for a faulty solder... If I have to send it in again I will be really disappointed in kenwood.
emt0423
Clintonville, WI
Encryption???
I'm looking for possible answers on encryption. Our department is looking at purchasing a couple of the new NX-5000 series radio but not sure if the encryption we use will work with theses radios. The Encryption our department use is DES-OFB. Any help is greatly appreciated. Thanks
sfd119
I would assume so. Our TK-5220s have DES-OFB/XL encryption boards in them and work with a KVL.
emt0423
Clintonville, WI
Ok. I hope they would. All the info I have read on them just states DES encryption. Not very specific to saying it does DES-OFB
kd4efm
EL98 Florida
The standard DES in the 5000 is not OFB strength. You have to get the option board for DES OFB.
Unless your using 52 bit, which I think your not, then ordering the board will be your option.
kd4efm Evans, sent using TapTALK on my HTC M9
RK3AAG
Russia
There is no any metions about DES-OFB or XL in Kenwood Price List. So I can suppose that No. Also I belive that XL is Motorola proprietary feature.
kd4efm
EL98 Florida
Okay, from what I have been reading, and what your only saying, the standard DES in the NX-5000 will talk to any other radio with DES,
the right CKR and the right ID, has to be the same, as I have tested this with my NX-5700 and TK-5720 demo radio.
(which I have AES-DES KWD-AE21K) and the two talk encrypted in P25 mode. (I use the KPG-113AE to program it)
If your using a KVL-4000 then the external modules (3 types) should work.
I can't tailor this reply to specifics but you should be able to get the kenwood dealer your talking to
or their Manufacturer's rep to come up with a demo radio.
If you need more information, you can contact me privately by my gmail and I will see what I can get
for you.
Here is a quick brief on it
- Data Encryption Standard (DES): 56-bit symmetric key algorithm
- 16 Multi-key List (user-selectable / per Personality programming)
- Stores: 1024 keys & 1024 Common Key References (CKR)
AES-DES
- Advanced Encryption Standard (AES): 256-bit symmetric key algorithm;
- Data Encryption Standard (DES): 56-bit symmetric key algorithm.
AES FIPS and DES
- Advanced Encryption Standard (AES): 256-bit symmetric key algorithm; NIST validated per FIPS140-
2
RK3AAG
Russia
Here is another good custom logo for Basic mobile head:
Spent 1 hour on trying to create it in Photoshop, but it didn't work with any settings (color depth, etc.). Finally converted file in ACDSee in 5 seconds and it works fine.
http://www.youtube.com/watch?v=t48C8HkZ9dA
sfd119
KWD-DE21K. We are running DES-OFB/XL in our TK-5220s, key-loaded with a Motorola KVL3000.
