Kenwood NX-5800 P25 compatibility question
wcardwell45
Quick question regarding P25 compatibility. I have a NX-5800 with FM/NXDN/P25 in 450mhz-520mhz. Is this able to communicate with a 700/800mhz P25 phase II system without the NXDN and 700/800 system being connected? I use the NXDN for company use however I would like to be able to scan/transmit on a sister companies 700/800mhz P25 system. Any help would be greatly appreciated. Thanks.
kd4efm
EL98 Florida
You will need a 5400 or 5900 for 700/800 use.
5300 is UHF only.
If you have a patch between you uhf and /700-800 wont mater, the console will provide the codec crossover.
Hope this clears the question.
n3obl
O AES-1024
PA
No. You want to communicate on 700/800 you need a NX5900
kd4efm
EL98 Florida
The other answer is get a 5900, add kwd5100, 5101tr and 5102tr and have the system admin add your radio to the system, then you can have a twin deck in your vehicle on one control head.
