Kenwood NX-800 error message
Atlanta GA
I'm getting this error message when I try to read NX-800:
No System Key File having the same system parameter as configured for NXDN Trucking System Zone was found, so the configuration data cannot be read.
Any thoughts or suggestions? Is there a work around?
Where is mmckenna (the Kenwood wizard) when you need him?
Thanks ahead of time!
MSS-Dave
Generally Central Florida
So, if you are reading a radio with a NXDN TRUNKING system in it, it will not display any info for that system unless your KPG111 software has a key for the system in it generated by the KPG110SM System Manager.
Can't help you on a workaround though, sorry.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
kayn1n32008
ØÆSØ
Sector 001
Are you trying to make changes to the trunking settings?
Do you need the trunk system?
If you are using the radio for conventional analogue or conventional digital only, and do not need the trunk system info in the radio, try and just overwriting a blank codeplug.
