Kenwood NX mobile DMR Roaming / MotoTRBO IPSC
ndejohn
Middletown, Connecticut
Hello all,
Happy 4th!
This may be posted elsewhere, but I can not find it. I am looking for some help in programming DMR Roaming in the NX line, particularly the mobile. I am and have always been a Motorola guy, so I am familiar with how IPSC is done on the Motorola side, but I can not figure out how to do roaming lists and things of that nature. I am more of a see-it-done, and then I can duplicate it in my radio, if you catch my drift.
So, if someone has a template that they wouldn't mind sharing that will show me a 2-site or more DMR Roaming system, I would appreciate it.
Thanks,
Nick
kd4efm
EL98 Florida
Hey Nick, did you get it to work like we talked? I know you still wanted to see it for comparison, I just don't have any other than NXDN like we talked over the phone.
ndejohn
To recap,
I have a System set up for DMR Roaming, and I have named it with the respective agency name. (ex, ABC Public Works)
Next, I have a Personality in this same zone for each of the departments under this agency (ex, PW, Water, Parks, and then I have PW Roam, Water Roam, Parks Roam, etc. - this covers both talk paths of the DMR Repeater)
I guess where I get confused from Motorola to Kenwood is Motorola has roam lists, where you program the Group Calls (PW and PW Roam), and then you set the Personality to look at that specific list for PW. Do I do the same in Kenwood? Do I create a Group Call List for Each department with the main and roaming group call ID?
ndejohn
So, I had it working once before, but I think it was only single site, not roaming between both sites. Then I deleted the whole zone, by choice. So, now I am trying to get it back it, but the right way. That is why I figured I would put it on here to see if anyone had anything they would be willing to share.
otobmark
NC
Roam 101:
-Channels set up to initiate Roam cannot be scanned or put in a scan list. Roaming is exclusive and cannot be combined with scanning.
-Each System (Type DMR Site Roam) is intended to follow the same simultaneous traffic across multiple sites, usually but not necessarily using same TG. NOT intended to service multiple traffic groups (Water, PW etc) in the same Roam System. Parks will need it's own Roam System, Water another and so on and you cannot scan between them. Typically each contained personality has it's specific frequency and color code and the TS and TG of the “traffic” being roamed (most of the time same TS & TG).
-The sites are not voted, and radio will only search for another site when it looses current site or signal goes below set threshold. If radio has been silent for awhile and you initiate a transmission the radio will first attempt to use last heard channel (traffic or beacon) and that failing it goes down the list trying to wake up a repeater/site.
-Nothing limits the configuration of the personalities in the DMR Site Roam system and you could use any combination of CC, TS (maybe Auto), TG or even receive TG lists. The results might be entertaining but probably not practical. You could use Auto slot and receive lists and the radio would land on first TG in list it hears and if set for talkback you could answer back if you’re fast. A total radio nerd might be able to work it but most mortals would be defeated by it.
-Main advantage of Roaming over scanning is the ability to initiate a call while letting radio find usable site. If a relatively short beaconing is set up it works pretty well. If radio has not heard anything in awhile, then it goes down the list of all personalities in the system trying to wake up a repeater which can take a few seconds (keep PTT pressed). I can use scanning and talkback to monitor/use multiple sites but it’s painful and easy to loose the TG mid conversation.
kd4efm
EL98 Florida
Got with Nick this morning and ironed out the end results over the phone with him. Just waiting to see the finished codeplug to validate it for him.
ndejohn
All -
So, as of right now, I still do not have this working. I have deleted everything, and I have the following programmed into my NX-5700:
Under System Information:
System 9 - XYZ Town
System Type - DMR Site Roaming
Unit ID 1234
Noting else is filled in or checked under System Information
Personal Features Information:
Everything in this box is basic/default/unchecked - No changes made here, other than unchecking Manual Dialing, Open Voice Channel Mode, and Active Site Hunt
Personality Information:
I have 6 channels: one for each of the departments. All the pertinent information is in under the General tab and the DMR tab. For the Selcall on PTT, I have the associated Group Call in this section that pertains to the channel name. Public Works would be the PW group call.
Now, I have another system set up as the following:
System 10 - XYZ Town Roam
In this system, I have all the same information, except I have the frequencies and group call IDs for the roam sites.
Lastly,
I have a zone setup with all the channels from System 9 and 10. I see the channels bounce around depending on who is talking on which channel (DPW, Parks, etc), but again, no audio.
My problem is I can see a site via the green receive light indicator on the control head, and the signal strength indicator but I get no audio. My company services this public works department, and they are predominately Motorola. I have a Kenwood NX-5700, and I would like to make the system work on the Kenwood
Any idea?
Thanks,
Nick
celltech25
Benton
Does the system use privacy or ras keys? Ipsc and kw site roaming are pretty easy to setup. You can pm and send me your file
ramal121
Lots and lots of watts
Calif Whine Country
Trying to follow you here.
For one you don't put multiple talkgroups into one site roam system. Each talkgroup needs its own system. You also need to have the talkgroup ID the same for all sites in a roam list.
Re-read otobmarks post, it is explained pretty well. Or Evans will straighten this out.
otobmark
NC
Only set up one roam system which means 2 personalities (your 2 sites) which should be identical except for frequency with same single TG (no TG list). Get that to work before adding more.
What the part about seeing the active channel indicator light up without any audio sounds like the radio is landing on an active channel/conversation that is using a different TG other than the one you have programmed to roam, thus no audio. The radio should scan PAST unqualified traffic (wrong TG in this case). I'd probably have another radio (Not roaming) to check and see what TG/Traffic is actually stopping the scan on the NX in roam. This has been a bug on some DMR radios in the past but hopefully not now.
I'd send my present codeplug to someone here that is familiar with roaming to evaluate what you have. That there could be a repeater problem seems remote but I never take anything completely off the table.
