Kenwood problem
ajfollas
I have a Kenwood tk-790 with a tk-890 control head. It receives people talking and I can hear them, but when i want to transmit back it dosen't transmit even though the tx light comes on. I tested this by having a scanner on the same channel I was trying to transmit on. I am fairly new to radios and don't know what to do. I have a programming cable and software if that helps, Thanks!
Probably the best place to start with all this is the basics.
1. Where are you located (generally, city, state/province, etc)
2. Are you licensed to transmit on these frequencies? Do you have a valid license for any radio service?
3. Who is it you are trying to talk to?
ajfollas
Im not liscensed actually, that would be the problem. But out of curiosity what would you have to do to become liscensed.
ajfollas
I have a Kenwood tk-790 and was wondering if it could be programmed to be a ham radio to pick up the normal cb channels.
cmdrwill
So Cali
Your TK790 would probably be able to be programmed with Receive only Ham frequencies in the SAME band as the TK790's band. So one would need more information on your radio's 'band'. TK790 radios come in different bands.
"CB channels" are not the same as Ham frequencies.
OK, North Carolina,
So that puts you under the Federal Communications Commission.
There are not any frequencies you can use that radio on that do not require an FCC license.
About the best you can do is to get your amateur radio license.
The TK-790 comes in a few models, frequencies are 148-174MHz or theres a 136-156MHz version. Ideally you'd want the 136-156 so you can use it on the 2 meter amateur radio band (144-148MHz), although I believe it's possible to trick the higher split model into working lower.
It will not receive on the CB radio band, it's physically not capable to make it work on those frequencies (26-27MHz).
So, a couple of options….
Sell the radio and use the proceeds to buy a CB radio of your choosing. That'll get you something legal that you can use on the CB bands.
or.
Get your amateur radio license and find someone to program the radio with amateur radio frequencies. The technician class license isn't hard to get, but finding someone to program the radio might be a challenge.
cmdrwill
So Cali
ajfollas, make sure you have your radio programmed for Receive Only until you get your license.
Maybe mmc can help with programming questions as he is the Kwoodie expert........
westcoaster
Sounds like the transmit frequency could be different than the receive frequency...
It also sounds like you are new to radio with the way you have been mixing up some of the terminology.
As unappealing as "get your license" may sound, there are courses and tests for amateur radio that can be quite beneficial in gaining some fundamental knowledge.
I took a course at my local amateur club, they ran through the course material, hosted the test and submitted for the call sign. I also received a one year membership in the club as part of the course fee. Your local club may have something similar.
