Kenwood tk-380
garybflo
Hello, I'm new here. I'm trying to program my TK-380 with the software KPG-49D and I have everything I'm trying to do but setting a priority channel. Can someone tell me how to do this. I searched the web and they talked about the software KPG-60D but from what I can find out, this is DOS software that runs on win 95/98 and I got rid of this back in 95/98. is there another software that can be used for this that is window based?
cabletech
Puget Sound
KPG49D is the correct version of software for the 380 radio and is Windows 95 thru XP solid and Vista most times but trouble on Win 7 and not for Win 8.
As for priority, do you have a scan list made?
Under ediet then is a drop down for scan settings, this here you set the time of scan and priority.
garybflo
tk-380
Thank you cabletech, I see what you are talking about.
Under scan type = fixed or list ( I changed it to list and see where you put to scan )
revert = selected or selected + talk back )
dropout delay = 3
dwell time = 3
lookback A = 0.50
lookback B = 1.90
But I can not find where to set channel 1 to priority. What I have is 10 channels scanning but 1 channel if they are calling to me it needs to break through so I can hear it even if another channel is talking at the time, and I need to talk back on that channel as well which I understand is the delay time set.
thank you for your help
ramal121
Lots and lots of watts
Calif Whine Country
Your TK-380 is set to trunking as a model type. Priority scan is not available for trunking, that's why it doesn't show. If you do not have any need for LTR trunking, you're better off setting the model type to conventional only. Priority scan will then be available. However, you will need to start from scratch in your programming after changing this.
Accessed by the "model" pull down menu.
