- Joined
- Nov 27, 2017
- Messages
- 9
Okay so my radio is not receiving very well on the bench. (5w portable not being received from 100 feet away and NOAA will not come in at all). That's not why i'm here, that's probably a hardware issue. I'll take pointers if yall got some though. The reason I am here is because while using the frequency adjustment tab on the test mode page I also decided to take a look at the open and tight squelch settings and I believe I was able to adjust the squelch settings at first (like the frequency adjustment) the slider for both the open and tight is now grayed out and going back and forth automatically between 67 and 69 "data".
What I would like help with is figuring out how to set my squelch again.
Some more background info: the squelch setting on the radio is set at 9 and it is still wide open. I have the latest firmware (1.22) and I am using KPG89D for programming.
Thank you for your time.
