Kenwood TK-790H
DO5MP
KiLa,Germany
Hallo, gibt es eine Möglichkeit, den Frequenzbereich eines TK-790H zu erweitern? Das Gerät muss ab 144 MHz arbeiten, um für Amateurfunkzwecke genutzt werden zu können. Ich suche nach einer Hardware- oder Softwaremodifikation.
Danke.
n3obl
ØAES-1056
PA
The software should handle below 148mhz freq. It will show error however accept them. The hardware section will need to be retuned to work below 148.
n3obl
ØAES-1056
PA
Most I have encountered seems tight in receive for below 148. Once adjusted it will be spot on but you loose a little up in the 170 range.
mrweather
The only x90 mobiles I've had to adjust for ham purposes were an 890 that lost lock below 445 MHz, and a 690H that I converted to 6m which required inserting brass slugs into the RX and TX VCO coils.
