Kenwood TK-D340E DMR
ct1emj
Silves, Portugal
Does anyone have a codeplug for Kenwood TK-D340E for DMR?
I have build my own programming file or codeplug from scratch, as no one use this type of radio in my Country.
I am not an noob when programming a codeplug from scratch and in this case, I can see that I go thru the hotspot in to Brandmeister, but not receiving audio from any other station if there is a conversation on that TG. Working fine in Analog with good audio and no issues. My request for codeplug is to compare and see where is my fault, as I believe that the problem is in DMR section of the software.
Thanks in advance
CT1EMJ
kd4efm
EL98 Florida
not hard to master, add your group ids to the dmr group list, then go to your channel add that information, and on ptt selcall, choose group
call, and select what group you want that channel to key.
These don't have a rx group list, so you would need to know what talkgroup to switch to if there is chatter coming across the repeater.
ct1emj
Silves, Portugal
Evans, many thanks for your help, is working like a charm. However Dual Slot Direct Mode, needs to be turned off.
In unit ID list, do I have to program all TG´s that I have in Group ID List or just my own ?
Once again appreciate your help.
dryfb
America
If you disable Group ID scan it may be selective on what it unmutes to, and if there's audio control in zone settings you may have to change that to get it to selectively unmute, at least that's how it is for NX radios.
ct1emj
Silves, Portugal
I am going to test it, as well the tone for ending a qso. I will post results. Many thanks
kd4efm
EL98 Florida
IN MY WORDS, I dont use the UNIT ID LIST, as doing private calls on BM, or DMR-MARC networks is frowned upon.
NOW, not saying you put in a users UID, and want to have a Name to it when they talk, have at it.
Group ID; helps to have the TG's you want to talk on or listen to, in this list. Otherwise, not in your list, GID Scan unchecked,
you wont be bothered with other chatter coming of that repeater, or your rPi / hotspot.
Glad your up and running!
