Mongerbl82
- Joined
- May 14, 2023
- Messages
- 82
- Reaction score
- 3
I have one of them and for some reason this program is not running through dolls it's running through windows and I mean like I said I'm using Windows 10
I have a laptop Dell running Windows 98 I might have to see if I can get the software to load up on there it's got the serial port and a USB
And where would I check the speed and everything yet
Well like I said before with the radio when I key up with the mic after about 5 Seconds it starts beeping I just got the correct microphone and it still does that so it could be with the radio itself
9600 8 N 1 is usually default.All right the commsport setting is at the lowest in that is 9600 I believe it is and the data bytes are five stop bites is one
So do I wanted to read faster or slower9600 8 N 1 is usually default.
But the radio should read/write much faster than that. It should be able to do 115,200
You know I didn't think it'd be this hard the program a radio I guess I'm just not used to kenwoods I have Motorola ht1000 and Vertex Standard vx160s HTS and they're easy the program I just need a mobile unit for my car that I can program myself
Hi so I just looked at this CD and the number is 076 k44 is what it starts with
Hi and do you know where I can get a OEM cable at a reasonable price and if so please let me know I would rather have that anyway cuz the cable I'm using for programming is a unbranded cable it's a single for it but it has Kenwood and also a plug for Vertex Standard vx160 and 180
All right thank you I will look on eBay again and see if I can find anything I found a few but what I found is unbranded and 90% of them are USB and I want a Serial Port connection
My biggest problem I'm having with the cable I have now is that unable to read or write to the radio and I need one that is serial portBlueMax49er has the FTDI USB KPG-46 cable for sale. I've had excellent luck with his cables, but I don't have any experience with that radio/cable combo.
