Kenwood TKR 850-1 Ver.1 Repeater
N4ADI
I have a Kenwood TKR 850-1 Ver1 repeater. It does TX full power but it has a busy green LED on constantly, with no local audio. It does not repeat, but it does read and write. Any ideas where to start.
Joe
N4ADI
ramal121
Lots and lots of watts
Calif Whine Country
Set the repeat function in the channel information. There is a squelch selection in optional features, maybe it will get rid of the constant green led. Receive speaker audio needs a jumper plug in the white connector on the back.
N4ADI
I tried what you suggested with no luck. i finally put it on the bench the transmitter is a mess 3.2 khz off freq pl dev1.2 transmitter is not spurious at full power. I guess someone was playing with this repeater before I got it . time to go check voltages see where that leads me.
Joe (N4ADI)
tweiss3
Is it time for Coffee?
Ohio
Is there something set for the DB25 on the back that has COR/PTT set to low? If nothing is connected, no voltage, PTT becomes constant.
I'd give it a good once over on the bench with the service manual.
ramal121
Calif Whine Country
Hooboy, sounds like you're going to be really into this. Sure sounds like someone was diddling where they weren't supposed to.
Not sure what you're going to find with a volt meter. I would do a full alignment with the proper test equipment. Do you have a service manual?
N4ADI
I am using the service manual from repeater builder. we have our 9vdc and 5 vdc on board . but we do not have disc audio ic 629 has vcc but no audio in or out. i am working on it a little bit at a time.
Joe
