Key transfer from KVL 4000 to KVL 5000
hellzmaen
Lawrence, KS
I just got a KVL 5000 was using a 4000 before and I am trying to transfer the keys over to the 5000 from the 4000. I used the USB to micro USB cable that came with the 5000 to connect the two KVLs but the 4000 then prompts me to enter the name for the device driver. Am I doing this correctly using the cable that came with the 5000 and if so where I could find the driver name it is asking for.
hellzmaen
Lawrence, KS
Thank you jeepsandradios! I kept seeing that on a few forums but it was always talking from one 4000 to another 4000. I'll dig thru the owner manual some more and find that section.
jeepsandradios
East of the Mississippi
Its the same regardless of KVL. Go to the screen for key sharing and follow prompts. You still need the TKN8209. The user manual is MN005113A01 and should have been on the CD with the KVL. It steps you thru it. You can get it on LXP if it didn't come in the box.
