Its easy to clean the contact pads. You'll need a q-tip and isopropyl alcohol, and a small Phillips screwdriver. Unscrew the 6 screws on the back of the scanner (2 are in the battery compartment) and the front face will come off. Remove it with the face down, and you'll see little black circles on the back of the keypad membrane. Gently clean those circles with the alcohol and q-tip, and do the same with the contract traces on the front of the circuit board.
Let it dry and reassemble. If you got dust on the LCD, remove it with a piece of masking tape first.
