MWKK
new software
Khanfar RSA v1.00 starts the new naming era after the software scope expanded beyond the older Analog Radio Hunter identity. This is a public rename and scope-reset point, not the first overall release of the project, and it presents the platform around SWL and HF monitoring, floating 2D FFT spotting, realtime waterfall rewind review, right-click SWL control, EiBi and live-spot overlays, mapping, replay, and analysis.
Made built-in EiBi, POTA, and SOTA
website
video
Khanfar RSA v1.00 is the first release under the new Khanfar RSA name after the
project scope expanded beyond the older Analog Radio Hunter identity. It is not
the first overall project release; the older Analog Radio Hunter line continues
below as preserved old releases. The public v1.00 positioning now highlights the
same SWL/HF, floating 2D FFT, waterfall rewind, right-click SWL control,
provider-overlay, mapping, replay, and analysis capabilities already present in
the mature runtime.
- Rebranded the public software identity to Khanfar RSA.
- Updated the product scope to reflect the broader multi-SDR operations console,
including the floating 2D FFT SWL/HF workflow and propagation-aware monitoring.
- Surfaced the floating 2D FFT up-to-120 FPS operating path for compatible
NVIDIA CUDA and 120 Hz display setups, including visible Renderer,
FFT Compute, and Actual FPS runtime status.
- Surfaced the built-in 120-second waterfall rewind workflow with paused reverse
browsing, magnifier, UTC or age readout, and bandwidth or time measurements.
- Surfaced EiBi schedule overlays plus POTA and SOTA live spot overlays as part
of the public v1.00 operator story.
- Surfaced the direct right-click FFT, waterfall, and Bookmarks controls used for
Pause Rewind, Return to Live, Spot Age, and POTA QRT filtering during SWL work.
- Preserved the older Analog Radio Hunter release history below as old releases.
- Continued the mature runtime, decoder, mapping, replay, and analysis feature set
under the new software name.
- Reset the public version label to v1.00 for the Khanfar RSA naming era.
jazzboypro
Laval
It looks nice, but unfortunately it just won't finish loading on my laptop. It gets stuck a 82%
MWKK
read website and pdf . Important Runtime Requirement: Install Microsoft Visual C++ Redistributable 2015-2022 (x64) before running this software
jazzboypro
Laval
I found it, seems it does not like my 7610, as soon as i unplugged the 7610 from my laptop it worked. Strangely SDR++ had the same issue while the 7610 was connected to my computer. Furthermore it appears that it's only USB 2 on the 7610 that does the problem.
avery_k
Broadcastify Feed Provider, Lake County, OR
Lake County, Oregon
Nice! This will be fun with my RSP1A & Nooelec. Now I gotta find the antennas for them! The WiFi analysis could come in handy too!
MWKK
Khanfar RSA , SOON .. 5ghz -2.4ghz Wi-Fi - 3D view Analysis - testing with Hackrf one at 20 msps . and more SDRPlay HF features capabilities and Fixes ...... Feedback is important for enhancements and fixes! 73s all ...
MWKK
Release: Khanfar RSA v1.01
April 21, 2026
Khanfar RSA v1.01 adds dedicated Wi-Fi and LTE analysis workflows to the
platform, keeps the upgraded ADS-B/AIS mapping workflow visible in the current
release, adds a display-converter and LO-offset workflow for QO-100 and other
converter paths so the main FFT and 2D FFT show translated RF frequency, and
includes an SDRPlay offset-calculation fix for the 2D SWL path.
- Added 2.4/5 GHz Wi-Fi Analysis workflow for wireless occupancy review and
live RF inspection.
- Added LTE Analysis workflow for LTE downlink inspection, scan panels, and
cell-analysis views.
- Added Display Converter / LO Offset workflow for QO-100 and other converter
paths so the main FFT, frequency controls, and 2D FFT can show translated
RF frequency while the SDR remains tuned to IF.
- Current ADS-B/AIS mapping workflow includes distance-from-home columns,
sortable aircraft and vessel tables, and configurable range rings.
- Fixed SDRplay RSP offset calculation in 2D SWL.
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Liking the app so far. Understanding that DSD+ integration is still in beta phase. Currently getting these pop up whilst starting the digital/DSD+ workflow. Running an SDRPlay RSPDuo, all other SDR apps are closed
FMPP file was extracted directly from the latest DSDPlus public release like I was advised to do in the app, it didn't come from another machine. Said dll is contained within the working Khanfar RSA\DSD directory and works fine on other instances of FMPP I run. I even re-run the SDRPlay API installer pointed to the aforementioned Khanafar directory, no dice! Any suggestions or is this a known bug?
Whiskey3JMC
images
ronenp
Hi
Hs someone suceeded to operate DSD or DSD-Neo ?
I get for both error burst low 0/10S 0.0% and it stop working
Regards
R
