Spleen
Westminster, MD
images
MWKK
For rar file use winrar software for unzip , for dsd and neo , will add soon youtube tutorials steps how to run everything from a to z
MWKK
For fmpp sdrplay its stay in beta and not continue yet in dsd implementation
MWKK
Next release will have sdrplay Bias-T and antenna selection and more swl audio filters and remote control from web page in lan with fft and waterfall and audio in local lan from any pc or tablet
MWKK
Khanfar RSA v1.02 - Feature Update
Major New Features
1) Real-Time DXwatch in 2D FFT
- Added real-time DXwatch integration directly inside the 2D FFT control panel.
- Usage flow:
- Open 2D FFT.
- Go to Control Panel -> Stations tab.
- In Source, select DXwatch.
- Live station rows show key spot data including:
- country flags
- DE callsign
- DX callsign
- mode
- spot observation/details
- Double-click any DXwatch station row and the tuner jumps to the exact occupied frequency.
2) SWL AM Filter Presets
- Expanded SWL AM preset workflow for faster tuning and cleaner voice/music recovery.
- Preset set includes practical profiles such as:
- Aviation
- HF AM
- Weak
- International Broadcast
- MW Local
- Fading DX
- Carrier Lock
- Adaptive Select
- Utility
- SWL restoration modes can be layered on top of AM presets for fading/noisy HF conditions.
3) HackRF One Decimation
- Added HackRF decimation presets (x1 up to x64).
- Effective visible span follows:
- effective span = sample rate / decimation
- This helps reduce visual bandwidth and improve readability in spectrum/2D FFT workflows.
- Decimation is saved and can be applied live when possible; otherwise it applies on next Start.
4) Advanced Gain Control for HackRF One
- Added direct HackRF stage control path:
- LNA gain
- VGA gain
- AMP toggle
- "HackRF Advanced" mode enables manual stage-level control.
- When advanced mode is OFF, the normal main Gain slider auto-maps gain behavior.
- Note: HackRF has no native AGC, so this advanced path gives operator-level manual control.
5) LAN Remote Control (HTML + WebSocket)
- Added built-in LAN HTML remote control surface for remote operation from browser.
- Added user-to-user remote workflow with KhanfarRSARemote.html (WebSocket client).
- Web Control (HTTP) default server settings:
- Host: 0.0.0.0
- Port: 5000
- WebSocket Remote Control default server settings:
- Bind: 0.0.0.0
- Port: 5454
- URL/target format:
- Web Control: http://<host-ip>:<port>
- Remote HTML client target: ws://<host-ip>:<port>
How To Use LAN Remote (Important)
A) Same PC only (local access, Web Control)
1. Set Host to 127.0.0.1
2. Set Port (example: 5000)
3. Start Web Control
4. Open browser on same PC:
- http://127.0.0.1:5000
B) Different PC on same LAN (Web Control)
1. Set Host to 0.0.0.0 on the main SDR host PC
4. Find host PC LAN IP (example: 192.168.1.50)
5. On another PC in same LAN, open browser:
- http://192.168.1.50:5000
6. If not reachable, allow the app/port in Windows Firewall on the host PC.
C) User-to-user Remote with KhanfarRSARemote.html (WebSocket)
1. On the SDR host PC, open Radio tab and go to Remote Control (WebSocket).
2. Enable WebSocket server.
3. Set Bind:
- 0.0.0.0 for LAN clients
- 127.0.0.1 for local-only
4. Set Port (default 5454).
5. On the remote PC, open KhanfarRSARemote.html in browser.
6. In the top bar, set:
- Host = host PC LAN IP (example 192.168.1.50)
- Port = 5454 (or your custom value)
7. Click Connect.
D) Practical Notes
- 127.0.0.1 works only on the same machine.
- 0.0.0.0 binds all host interfaces so LAN clients can connect using host IP.
- For user-to-user remote control, the remote user should open KhanfarRSARemote.html and press Connect.
- Keep both PCs on the same subnet/VLAN.
- If chosen port is busy, change to another port and reconnect with the new URL.
Peterdrowan
I get an error when I select pure dsp and then config. . Is there a solution. The app works apart from that under windows11 with RTL-SDR
Failed to open/save Pure DSP settings:
QDialog(parent: typing.Optional[QWidget] = None, flags: Union[Qt.WindowFlags, Qt.WindowType] = Qt.WindowFlags()): argument 1 has unexpected type 'bool'
Regards
P
Spleen
Westminster, MD
So you can't record WFM? Every time I try it says Narrowband Disabled....
MWKK
The Singularity of Khanfar RSA: Bridging the "Engineering Gap"
In the world of Software Defined Radio (SDR), there is a significant divide between experimental research tools and professional-grade operator consoles. Khanfar RSA occupies a unique position in this landscape. While many hobbyist tools exist, Khanfar RSA is one of the few platforms that has successfully bridged the gap between raw signal-processing power and a professional, unified workflow on Windows.
Here is why this software is unique, why it has few competitors, and why the "all-in-one" experience it provides remains rare.
1. Why Khanfar RSA is Unique
Most SDR software falls into one of two categories: Modular toolkits (like GNU Radio) or Application-specific receivers (like Gqrx or SDRangel). Khanfar RSA breaks this dichotomy by acting as an Operations Console.
The Fosphor-Console Integration: The core of its uniqueness is the high-performance integration of the gr-fosphor engine. While gr-fosphor is a standard component for Linux-based research, it is notoriously difficult to port to Windows. Khanfar RSA does not merely "display" a signal; it wraps the gr-fosphor engine into a polished, high-refresh-rate (120 FPS) interface that feels like a dedicated hardware spectrum analyzer.
Workflow-First Design: Unlike modular tools that require the user to build a "flowgraph" to perform a task, Khanfar RSA provides a pre-wired, operator-ready surface. It keeps RF control, decoding (AM/SSB/Digital), mapping (ADS-B/AIS), and IQ replay on a single screen. This minimizes "context switching," which is the biggest productivity killer in professional signal hunting.
Intelligent Signal Analysis: It includes professional-grade features such as CFAR (Constant False Alarm Rate) detection. This allows the software to dynamically adjust thresholds based on the local noise floor, enabling the detection of weak signals that fixed-threshold scanners would miss.
2. Why "Competition" is Scarce
The reason you don't see dozens of clones of Khanfar RSA is due to the extreme technical and architectural hurdles involved:
The "Heavy Lifting" of Cross-Platform Porting: gr-fosphor was built for the GNU Radio environment, which is native to Linux and relies on specific OpenCL/OpenGL/CUDA libraries. Creating a stable, high-performance Windows version requires deep expertise in low-level graphics acceleration and runtime management. Most developers prefer to write their own, simpler visualization engines rather than undertaking the complex task of "taming" the real gr-fosphor engine on Windows.
Development Cost vs. Market Size: Developing a console that integrates multiple SDR drivers, mapping APIs, real-time decoders, and a GPU-accelerated visualization engine is an enormous undertaking. Because the professional SDR market is specialized, there is little financial incentive for large commercial entities to invest the years of development required to build a "console" of this caliber.
The "Flowgraph" vs. "Console" Paradigm: The open-source community generally favors the "flowgraph" approach (where users build their own custom systems). Khanfar RSA represents the "operator" approach, which is a different philosophy entirely. It is designed for someone who needs to use the radio immediately rather than someone who wants to engineer the radio receiver from scratch.
3. The Future of SDR Consoles
We are currently in a transition period. For the last decade, high-end RF analysis was only possible with dedicated hardware RTSAs costing thousands of dollars. Khanfar RSA represents a shift toward "Software-Defined Instrumentation," where the hardware (SDR dongles) becomes a commodity, and the Software Console becomes the true "instrument."
As GPU technology improves and the need for portable, field-ready RF monitoring grows, we may eventually see more consoles emerge. However, Khanfar RSA currently holds a significant head start in having solved the most difficult technical barrier: making the high-speed Fosphor engine perform reliably and intuitively on the Windows platform.
Summary for the Field Operator:
If you have found in Khanfar RSA the speed, stability, and unified workflow you need for your rugged tablet setup, you are essentially using a "best-in-class" tool. You are not seeing competitors because most other projects are either building simpler tools for hobbyists or more complex tools for researchers, leaving the "professional-grade console" space largely occupied by this singular, highly-optimized solution.
Fredo68
I thought this software looked interesting so I downloaded it. Got the RAR file but it requires a password to decompress?
MWKK
Khanfar RSA: The Only Windows Software Running the Real gr-fosphor Engine at High FPS​
A Gap Nobody Else Has Filled​
For over a decade, the SDR (Software Defined Radio) world has had a well-known split. On one side sits gr-fosphor — the GPU-accelerated, OpenCL/OpenGL-driven spectrum visualization engine built for the GNU Radio ecosystem, developed by Sylvain Munaut as part of the Osmocom project. It produces a fluid, "phosphor persistence" style waterfall and histogram display that makes brief, bursty signals visually pop in a way flat, traditional waterfalls don't.
On the other side sits Windows — the platform most hobbyists, RF enthusiasts, and field operators actually work on day to day.
The problem: those two worlds have never fit together easily. gr-fosphor is Linux-native, and its own documentation is blunt about the difficulty of a Windows build — the standard Microsoft Visual C++ compiler can't even compile it due to C99 constructs it doesn't support, forcing developers toward the Intel compiler or manual Clang builds. It's possible, but nowhere near trivial.
That's the gap Khanfar RSA (and the broader family of Khanfar SDR tools) has stepped into — and, as of today, it appears to be the only software in the world that combines the genuine gr-fosphor engine, native Windows packaging, and a high-refresh-rate (120 FPS) GPU-accelerated display in one ready-to-run application.
What Makes It Different​
Most SDR software falls into one of two camps:
  • Modular toolkits like GNU Radio, where you build your own signal-processing flowgraph piece by piece — powerful, but it demands real engineering effort before you see a single waterfall.
  • Application-specific receivers like Gqrx or SDRangel, which are polished and ready to use, but implement their own visualization engines rather than the fosphor engine specifically.
Khanfar RSA occupies a third space: it wraps the actual gr-fosphor engine — not a lookalike, the real GPL-licensed codebase — inside a single, pre-wired Windows executable. No GNU Radio install, no flowgraph building, no compiler wrangling. You download an exe, plug in an RTL-SDR, Airspy, HackRF, or other supported device, and the fosphor-style waterfall is running.
Why It's Genuinely Hard to Compete With​
This isn't a case of nobody else wanting to build something similar — it's a case of the engineering barrier being unusually high:
  1. The Windows port itself is a known pain point. gr-fosphor's own maintainers acknowledge it's non-trivial to build on Windows, requiring workarounds for compiler incompatibilities and careful handling of OpenCL/OpenGL driver behavior across GPU vendors.
  2. It's cheaper to build something simpler. Most developers who want a nice-looking waterfall on Windows write their own lightweight rendering engine rather than taking on the complexity of taming gr-fosphor's OpenCL pipeline plus GPU driver quirks across NVIDIA, AMD, and Intel hardware.
  3. The market is a narrow niche. A GPU-accelerated, fosphor-specific, Windows-native SDR console sits at the intersection of a fairly small user base (RF hobbyists + Windows users) and a fairly large engineering lift — not an attractive ratio for most commercial software teams.
Put together, those three factors explain why, despite gr-fosphor being public and GPL-licensed since the 2010s, nobody had packaged it this way for Windows users until Khanfar did.
The Practical Advantages​
  • Zero setup friction — a single exe replaces what would otherwise be a GNU Radio + gr-fosphor build process.
  • Multi-device support — works across RTL-SDR, Airspy, HackRF, and other popular hobbyist SDR hardware, with some tools in the lineup (like Khanfar Spectra-All) combining multiple devices into one wideband display.
  • Free and open source — the code has been published on GitHub under GPLv3, meaning it's inspectable and forkable, not a black box.
  • High-FPS, GPU-driven rendering — a smoother, more responsive waterfall than most CPU-rendered alternatives, well-suited to spotting short, bursty transmissions.
  • Workflow-first design — RF control, demodulation, and visualization live on one screen instead of requiring a hand-built flowgraph for every task.
A Fair Word of Caution​
It's worth being clear-eyed about what this software is — and isn't. A smooth, GPU-accelerated waterfall is a display advantage, not a substitute for the calibrated, traceable measurements you'd get from dedicated professional RTSA hardware (Signal Hound, Aaronia, etc.). Those instruments bring purpose-built RF front-ends, wider instantaneous bandwidth, and calibration that no amount of rendering polish on a consumer SDR dongle can replicate. Khanfar RSA's achievement is real and specific: it solved a genuine, long-standing Windows packaging problem for the fosphor engine. That's a meaningfully different claim than being a replacement for professional-grade RF instrumentation — and it doesn't need to be, to be valuable.
The Bottom Line​
As of today, Khanfar RSA stands alone as the only known software that puts the real gr-fosphor engine, native Windows support, and a 120 FPS GPU-accelerated waterfall into a single free package. Whether that remains true depends on whether other developers pick up the now open-sourced codebase — but for now, it fills a gap that the broader SDR software ecosystem left open for over a decade.
