Kirkwood
paperclip-kc
I am going to be around Manchester Rd & Woodlawn Ave in Kirkwood next week. Is this a good area for picking up STL City PD and other PD in the County? What ST.L city District Dispatch should I program the ID for?
justinnmr
St. Louis, MO
The 2 Kirkwood PD freq's are 155.25 & 159.045.
I highly doubt you will be able to pickup STL City PD due to their extremely weak transmitters.
You should be able to pickup a bunch of the county precincts depending on your system. I recommend just seeing which county precinct freq's you can receive. Those can be found in the St. Louis County freq's area (only 7 precincts, 3 of which share a frequency).
MaximaGuy
I'm out there quite a bit and picking up the city will be next to impossible even with a 800Mhz antenna.
K0AZV
St. Louis County Missouri
If you are at the apartments that we chatted about PM a few weeks ago, I don't see any problem with picking up the STL City PD. Might have to tweak your antenna setup a little bit to do it but it should be doable.. All of the county PD freq's should come in really good.
Max...
paperclip-kc
Max...
You were right. I pick up the St.L city from the apartment. I could pick up in ever room but the Kitchen.
