KPG-111DN Question
ffemt25
Short Gap, WV
I know its probably been asked before but I can't find it.
Are you able to copy zones from one profile to another? Like if I wanna pull a zone from one saved file to another without having to re enter all of them into it. Is it possible?
dryfb
America
Use the source file feature. Go to tools>zone merge>copy the zones on the right side to the left side. Then save as, select source file. In your other codeplug, go to open>then select the .sdt file. Then go to zone merge again>copy from the right side to left. I believe all info for TOT, optional signalling should save using this method.
ffemt25
Short Gap, WV
I'm trying to do this but for some reason it doesn't seem to bring up the source file. I should also mention I'm trying to go from an NX700 to a NX205. Does this matter?
dryfb
America
Shouldn't matter, here's screenshts showing what to do. After the 3rd and you saved it, open the .sdt file, and make sure it's the .sdt file. Then it should have the source file zones populated
ffemt25
Short Gap, WV
Thank you so much It worked like a charm!
