KPG-112D problem
arlo
I tried to read a TK-5220-K P25 with my KPG-112D ver2.01. I got an error message that said "To read, the latest version of Field Programming Unit must be installed." Does this mean I just need a newer version or does it mean I need a special version for P25? If a special version, is it available to none dealers?
It usually indicates that the firmware in the radio is newer than the KPG software. Updating to the latest KPG-112 software should address the issue.
The latest version is:
KPG-112DN V2.33, released in January of 2016.
Be aware that the "DN" software will only allow narrow band above 150.1MHz.
I'll add:
The latest version of firmware for the TK-5x20 radios is version 2.18, released January 2016.
arlo
OK. I just found the invoice where I purchased the KPG. It was August 2012. A lot older then I thought.
