G5 software problem
K9KLC
Southwest, IL
Your choice, either change as @K9KLC suggests or live with symptoms you are experiencing. This is how they work.
It grabs a site from the list programmed with good decode, not necessarily the best signal or closest tower.
Yep and it may do it at a whim too, even moving across a room, I've had mine switch sites when in spectrum scan. I think perhaps he doesn't fully understand how the Unications work or how to actually program one for a FD or other public service situation where getting the call reliably is needed.
KK4ELO
Smithville, Tennessee
I know of no one, actually using for fire and paging that programs it the way you have. The Unication without notice may switch sites at the most inopportune time and you'll miss a call or traffic. Good luck to you, I cannot advise further.
Well, considering I have it programmed exactly the same way as the 4 radio shops covering 5 counties, I'd say I'll be ok. Worked all this time so far. If you'll remember I said it locks on to a site and stays there until I leave the area. Some tea that's 3 counties away from my home area. But thanks for the advice
KK4ELO
So your saying this is the only place in the country with multisite coverage using these pagers? What does everyone else use?
K9KLC
Southwest, IL
I cannot comment what everyone else uses, only my experience in my area. "Normally" yes once it locks on to a site it will stay there however the only way to insure that is what I mentioned. I wasn't being rude nor condescending, simply what my experience here in my area with FF has been. You mentioned an issue, in post #16, and I offered a solution to the issue with it locking onto one site and not the other. If it's working for you, then it's not a problem and no solution would be needed.
K9KLC
Southwest, IL
If you have yours programmed the way the others are, and no one else is having issues, then I have no answer unless it's possibly a location thing where you're actually turning your pager on at. I mentioned above I can go to a different room in my house and if I have it on anything but the one site, it may or may not come onto that site in any other mode.
