KPG-1D PDF
Robert721
Klein, TX
anyone have a PDF on the programming procedures? User manual?
hitting some issues. It's all new to me.
Robert721
Klein, TX
I was able to write one zone but there are 3 in the uhf 2 in the vhf. I can’t find where to program the panel keys. I can’t get dual RF display on the head. Just ignorance on the programming flow and where to find things
tweiss3
Is it time for Coffee?
Ohio
The common function advance manual can be found here https://nx5000.com/storage/uploads/NX-5000_Common_FUNC_K_F_Ver220_EN_20170630.pdf
From what I understand, the KCH-19 (standard) head will only show the active deck. KCH-20R (feature) and KCH-21 (HHCH) can show all decks at once.
Two down from Zone/Channel is Key Assignments. You should be able to assign one key to cycle through the active RF deck
Robert721
Klein, TX
I have the 20r. I think I have that pdf. I’ll compare the info tonight. I think that one has the basic radio functions, correct? (I’m at work and all the files are on the pc at home).
thanks
kd4efm
EL98 Florida
thanks
set a soft key for multi-deck view
then you will be able to toggle between primary view and multi-view.
Key Function List (Appendix)
Multi RF Deck ViewToggles Multi RF Deck View between on and off.This function is available only for Mobile.
This function can be configured if Multi RF Deck is enabled, and "KCH-20R (Featured Panel)" or "KCH-21R (Handheld Control Head)" is configured in Control Head 1or Control Head 2.
This function can be configured for a transceiver having firmware version 1.60.00 or later.
Robert721
Klein, TX
I have found a four part video from speciality communications. Is for a handheld but it’s covering most functions in the software
