Kpt 20 programming
gizmp
baldwin park ca
I have a KPT-20 Programer, I dont have the cable for programing a tk-820. does anybody have the cable wiring diagrams so i can build one myself as they are not being made anymore. Or a picture of the cable. Not sure if it plugs into the mic jack or some connection inside the unit
thanks
AD0TY
Indiana
That's kind of an odd connector isn't it? They don't program through the mic jack.
gizmp
baldwin park ca
IIRC, the programming cable connects to a connector inside the radio.
I guess so. Some say you program Eprom but I didn't find it there. The only Eprom I found was for the PL code that was on another board on there
Sent from my SM-N950U using Tapatalk
ohiohonda
The programming port for that repeater is on the top near the front board. If I remember correctly since it has been around 10 year since setting up a TKR-820. The programmer I have/had was a small black enclosure that had the program cable attached but also had a place to insert the eprom for programming.
After researching I have/had the KPT-50.
gizmp
baldwin park ca
well, I'm talking about the Mobile unit TK-820. I"m able to program the Eprom for the Pl tone. but cant adding any freqs. I don't really want to send it to a radio shop. i got several of them., in fact i'm planning on getting some tk-880 to replace them. but i'm just thinking on just using the tk-820 as base stations and have them at my families homes
KK6ZTE
California
One warning, they aren't narrow band compliant so they can only legally be used on ham frequencies. (Possibly GMRS if they're type accepted)
needairtime
CO, USA
Sorry about the necropost.
I wonder about the similarities between the TK-810 and the TK-820, both of which need to be programmed by the KPT-20. Anyway I wonder if the TK820 looks like the TK810 programming port pictured below, which I probed to this as far as I can tell:
pin 1: DO - readback TO programmer
pin 2: DI - data TO radio
pin 3: CLK
pin 4: CS
pin 5: NC
pin 6: Power (? - through an LDO on board as far as I can tell)
pin 7: VSS
pin 8: NC
This connector is underneath the top cover of my TK-810. Please verify to make sure pin 7 is actually GND as well as pin 5 and 8 are truly not connected before trusting this pinout, if indeed it is the same connector. Now the other end of the KPT-20 I don't know but I would expect the cable to be run in parallel with the 8 pin connector as these pins on the connector are connected to the eeprom.
The reason why I'm posting this is that I'm sort of looking for someone with a KPT20 to program and read back a config eeprom so that I could try to reverse engineer it - to be able to program my TK-810 at will without the KPT-20.
Apologies again for both the necro and the request...
Thanks!
Reelfishguy
Kenwood did make a ZKIT to make them narrow band compliant. It consisted of a higher stability TCXO, a different crystal filter for the receiver and some other miscellaneous parts.
