KVL7000
2wayfreq
NM Kirk City
Hey All,
Has anyone configured one of these yet? Any problems sharing keys from a KVL5000? What transfer cable did you use?
MatRat80109
Colorado
Hey All,
I just got a couple of these. I used my KVL5000 to APX6000 cable. The 7000 has a GCAI connector just like an APX6000. Transfer was similar to 5000 to 5000.
MR
2wayfreq
NM Kirk City
MR
So, you used the KVL (CKN6904A) MX Connector to APX6000/8000 GCAI Keyload Cable? Also, where are the Diffie Hellman settings? I looked under VPN advanced settings but no dice.
Project25_MASTR
TX-COMU
Texas
I'd have to look at the TWI especially as the MX to MX legacy KVL to KVL cable is concerned on it it's pinout but I was looking at a few of the P/N's listed for the new keyload cables and some appear to be older cables that have had an additional description added. One of the things I'd like to try, HRS-10 to HRS-10 cable using nothing but HRS-10 keyload adapters. Like I mentioned, depending on how that legacy KVL to KVL cable is pinned out there may need to be a crossover of TX-RX lines (a null modem) in the HRS-10 to HRS-10 cable.
That would be a big deal because HRS-10 to HRS-10 cables are inexpensive and for all intents and purposes, the GCAI portable adapter is fairly cheap too. Seem to remember a similar setup for the KVL6000...and I still think the KVL7000 should just be called the KVL NEXT.
2wayfreq
NM Kirk City
I know why, but I wish they would've kept the legacy MX connector so I could use the old transfer cable.
2wayfreq
NM Kirk City
Looking to see if anyone has are part#s for GCAI to APX and NEXT Link Layer key generation and Auth Center Network/RJ-45 interface cables? I seem to have just keyload. I'll re-check these.
Project25_MASTR
TX-COMU
Texas
Per the KVL7000 UM, you use the programming cables and plug them into the USB port on the KVL. You may be able to do that with the KVL50000 (I don't think the RDNIS drivers were ever in the KVL4000) as well. Similarly, the mobile GCAI LLA cable and XTS LLA cables are just serial programming cables.
2wayfreq
NM Kirk City
The KVL7000 has no USB or Serial Ports, just GCAI. Not all of the cables have come in yet, so I may be missing a specific LLA Cable.
Project25_MASTR
TX-COMU
Texas
Per the manual, you need the USB Host Adapter and then you just use the regular USB programming cables.
CB000847K06
SCFDCOMM
have one as well but havent had a chance to synch up with KMF or copy from KVL5000 yet either. Cables just arrived recently.
dwgelle
Meeker Co.- MN
Our old one is the KVL3000 plus, is it able to share to the 7000 easily like from a 5k to 7k? I'm not seeing anything in the reference guide.
