Hays uses both the LCRA P25 sites and the LCRA Open Sky Sites. San Marcos PD and Hays SO use the Open Sky systems and occasionally Patch to the P25 system. All Fire and EMS Ops in the County appear to be on the P25 side of things. No Commercial end-user product will let you monitor the Open Sky side of things. An SDS in either flavor will be fine for monitoring LCRA Comms and will give you future protection should they ever decide to start employing LSM sites if that is your main concern. If you're just looking for a capable scanner to monitor LCRA without all the bells and whistles, then you might also consider the BCD325P2/996P2, Home Patrol 2, BCD 436/536HP, or even a Whistler TRX-1. All are very fine scanners and are capable of P25 Phase 2 decoding. If your going to be doing a home monitoring station you might also take a look at SDR (Software Defined Radio) options as well.
