L-2098 Site 2 Ottawa Area
DaveH
Ottawa, Ont.
Site 3 and 5 both show CC = channel 11 (141.615).
Site 3`appears to be single-channel (composite) with voice (IDAS).
Site 4 shows CC = channel 12. Do not hear anything on 143.490 which is only
frequency unaccounted for that I am aware. Still a few unknowns.
Dave
mmisk
Ottawa Canada
Hello I am still here following activity when I can,
I am supposed to be retired, but sometimes just as busy as when I was working!
Mike
DaveH
Ottawa, Ont.
Site 1 143.055 CC is now reporting Site 7 as neighbour but I can't get a channel number for its CC.
Possibly it's a new frequency, or a VC has been taken from another site; but Site 1 VCs
are still all used; and Site 2 as well (4 each).
Dave
mmisk
Ottawa Canada
L-2098-7 shows CC 12 ???
Here is what I show for 143.055:
Sync:+NXDN48 TB CCDATA SRV_INFO
Sync:+NXDN48 TB CCDATA ERR4 ADJ_SITE_INFO Neighbor L2098-2 CC=6 1 Neighbor;
L2098-3 CC=11 2 Neighbors; L2098-4 CC=12 3 Neighbors
Sync:+NXDN48 TB CCDATA SITE_INFO
Sync:+NXDN48 TB CCDATA ADJ_SITE_INFO Neighbor L2098-5 CC=11 4 Neighbors
;► L2098-7 CC=12 ◄6 Neighbors
DaveH
Ottawa, Ont.
Site 1 now shows neighbours 2-7.
Site 3 CC 141.615 is Channel 11. Site 5 has same CC Channel # (11).
Sites 4,6,7 have CC Channel #12, which I think may be 143.490 but not verified; anyone care to check?
Most of the sites >2 may be 1-channel sites, same frequencies re-used but far enough apart
and low power to not interfere e.g. Aylmer and Buckingham.
Dave
mmisk
Ottawa Canada
152.720
141.615 CC #11 seems to be a composite control and voice frequency.
141.135 is a voice frequency, carried TG'S 5011, 1001, 5012
mmisk
Ottawa Canada
143.190
Dave
143.190 could be a valid VC, with TG 1001 active
mmisk
Ottawa Canada
OK Dave, will check it out tomorrow when traffic is busy, too quiet today.
Interesting how it is naming the CC numbers▼
Sync:+NXDN48 TB CCDATA ADJ_SITE_INFO Neighbor L2098-2 CC=6 1 Neighbor; L2098-3 CC=11 2 Neighbors; L2098-4 CC=12 3 Neighbors
Sync:+NXDN48 TB CCDATA ADJ_SITE_INFO Neighbor L2098-5 CC=11 4 Neighbors; L2098-6 CC=12 5 Neighbors; L2098-7 CC=12 6 Neighbors
DaveH
Ottawa, Ont.
Whoever just added a bunch of frequencies to these sites, those are all repeater inputs, and don't belong in the listings. Looks like it's straight from TAFL.
Also, the channel numbers in site detail are not correct, the system won't be trackable by scanners or SDR receivers. For example, Site 3 141.615 is channel 11.
Dave
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Dave
Questioned the submitter about the points you brought up.
Apparently, a TRX-1 scanner will receive the system as it was erroneously listed. But, I know the TRX's only pick up the frequencies conventionally, so I'm not surprised.
In any case, I hope the listing is back to normal. https://www.radioreference.com/apps/db/?sid=9894
DaveH
Ottawa, Ont.
Dave
Nothing heard on 143.490 including when the CC 141.615 converts to VC, which you'd expect
to happen only when all other VC's are busy. Site 3 is single channel.
Dave
